Will the Fett263 electrostaff work on OS5.9?
Will the current Fett263 Energy Weapon / ElectroStaff blade style compile and function on ProffieOS 5.9?
I know the style generator currently labels it as an OS7 style, but I’ve seen people using this style for years, long before OS7 was released.
Has anyone tried the current generated version on 5.9, or does it use functionality that was added in OS7 and therefore won’t compile on older releases?
Style formatting changed significantly since OS5, you’ll need to update to OS7 or 8 to use current library, the current code cannot be run in older OS and will not compile.
You can use your config from OS5.9 to update to OS8, then add the new styles. Older styles run on new OS but newer styles do not run on older OS.
