I have an old Canon printer. It works fine, but there is no way to print from Android or ChromeOS to it.
I was hoping to cobble together a print server or some sort on a linux box that would make that possible, but apparently that is now hard, because Android doesn’t support standard printing methods, like postscript I guess?
Canon printer ink is also rather expensive. (Tried non-canon ink once, the results were not good.)
So I looked around. Checked wirecutter, that sort of thing… And came up with the Epson Ecotank 8550 I was all excited about this printer last year, and then I found out that it doesn’t support linux. That would mean that the computer I use the most couldn’t print to it. So I gave up on buying a printer for a while.
For whatever reason, I recently checked again, and I found out that the Epson Ecotank 8550 now does support linux. But while I was reading up on it, I did find out that the printer clogs for some people, and that the print quality isn’t as good as some other printers. In fact, the printer I have is probably better. A printer downgrade doesn’t sound very exciting.
So I gave up again.
But then it got me thinking, maybe I need two printers. One for photos and one for office stuff. I own some expensive camera gear, and it would make some sense to have a good way to print out some of the pictures i take and hang them on the wall, or give them as gifts. So I started researching large-format photo printers. And I had just started getting excited about the Canon PRO-1000 (the ink for which costs as much as a crappy car) when I found out that it doesn’t support Linux…
Is it really too much to ask that someone makes a printer that prints nice, doesn’t cost an arm and a leg to use and supports Linux? All the printer manufacturer would have to do is to document the protocol, and someone would write a Linux driver for it.
Wonder if I can build my own printer? It might be easier…
Or maybe a laser etching print head? Or a scanner? Or a plotter head? Dye sublimation? UV curing print head? DVD-like information storage head? Mechanical hold-punch heads? PCB drilling heads? The list of possibilities would be pretty long.
I think we’d need more pinouts though
