I see these fonts referenced in fett263s blade builder, but i can’t find matching sound files anywhere. How do I get them? Sorry if this has been asked before. I did search to find, but came up empty.,
Thanks!
Some fonts have them, some do not.
wow! a response from the man himself. thank you so much for everything you have done. i am loving all of this!! for the fonts, would they be named as preon.wav, pstoff.wav, etc., or do i just have to recognize the sound byte and rename accordingly?
If the font has it, then it would already be called that.
Now, you could perhaps take a quote from one font and make it a preon for another, the sky is the limit.
Glad you like it. I try to make sure every question on this forum gets an answer.
Only time I don’t bother is when someone else already provided the right answer.
You can create your own if you have something in mind. Make sure it’s 16 bit mono 44.1kHz WAV format and name it correctly.
