Hey guys, I’m pretty new to lightsabres and this is my first time using proffie so I need some help from the council.
I Just bought a Luke VeeOne form korbanth and I want to go about updating it to OS7 as well as adding my own custom blade styles. The issue is it has a crystal chamber and accent LEDs that are coded in a way I cant understand. I would have expected the number of blades to be three or possibly four, one for the main blade, one for the crystal chamber and one or two for the blinking arrows on the control box. However the config lists five blades, it seems the crystal chamber has been coded as two separate blades, one for the top LED and one for the bottom. The blade styles that appear reflect this. As a result I am unsure as to how I would add a blade style to the crystal chamber.
I am looking for help understanding how the board knows what blade style is for what blade, why they might have used five blades and how I would go about setting up a new config file after updating to OS7 so I can create styles for the chamber.
P.S. I don’t know how the board is wired and its glued in, its not coming out without breaking something. is this going to be an issue?
Here is the blade config;
WS281XBladePtr<1, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<1, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin7, -1, -1, -1>(),
SimpleBladePtr<CH2LED, NoLED, NoLED, NoLED, bladePowerPin8, -1, -1, -1>()
, CONFIGARRAY(presets) } ,
Hope you can help.
