I’ve started working on a webusb tutorial for proffieos.
The idea is to direct users who bought a pre-installed proffie to this tutorial first, and if they are happy with it they won’t need to worry about any of the programming stuff.
Thank you very much for that. I know this has been there the whole time, but I never really thought of how it can edit so easily. In my mind it was just remote control. This is gold for referring people to in the future!
Interesting observation: the interface shows presets start at “one” as opposed to zero…which is what presets.ini uses, so does it actually virtually shift by +1 for the GUI?
“one” and “two” are just the names of the presets. (The argument after the styles in the preset array.)
Maybe the note "Make sure your board was programmed with WebUSB support. (Webusb was selected in Arduino->Tools->Usb type) should be moved up top as part of the setup?
Maybe, but since this tutorial is meant for people who bought a hilt with a proffie already in it, that might not make much sense to them.
Hi, i try to use in local (off line) but it makes error whit the service workes…it’s possible to fix it whit a local host?
I don’t think it can run from localhost. Webusb requires a secure domain and localhost doesn’t count.
The easy way to run it offline it is to install it.
Here is how: Use Progressive Web Apps - Android - Google Chrome Help
