But if the velocity is higher than needed, you also have to move the saber much further to trigger, effectively creating a “maximum speed”, which I suspect was not intended.
Any chance we could get a video clip of what these tests looks like when performed?
I feel like I might be stabbing / thrusting quite differently.
For ignition, I think I mostly do this (although not necessarily pointing angled downward)
It’s like if you had an inch of water in a glass and you toss it out. There’s a definite “stop” at the end.
Whereas a stab is more of a “run him through” motion… if that makes any sense.
Yeah, the motion in this video is far too short to count as a stab with my method. I’m going for the “run him through” stab with optional lunge, so the thresholds are perhaps too high.
I think i can get it to detect shorter stabs by tweaking some thresholds. Let me try some changes this weekend.
So, let’s say we get this working well… It’s definitely a different type of gesture than the current “stab” (which is actually hitting something with the tip of the saber.). So how do we see this going…
- We use this to replace the current “stab”, perhaps controlled by a define.
- We create a new gesture (thrust? air-stab? ??) with a new event for this? Some props call this “thrust” to separate it from stabs I think, but it’s not clear to me what we actually want.
- Let each prop do whatever they want.
- Something else??
Is this possibly part of the solution regarding the lack of motion detection during translation in general?
I came across that issue again, when I gave a sword buddy a saber and two movements that are super common in eastern and western sword traditions were silent to their astonishment. It’s my top wish feature, as a motion centered guy.
Edit: I’ll try it I think it’s half of it.
You mean straight x/y/z movement?
That. But curved movements without a lot of rotation also. Like lifting the saber up to block an over head strike. Some very well known kata (routines) start with a lunging thrust, then a lifting block.
Here’s the oldest example on film, since this guy choreographed the kata. It’s the first 2 movements that repeat before the next transition.
It’s also something like the german longsword guard the “ochs”…or a scoop up version to get to it.
Just for reference, I made my prop work like this because it works for me:
- Hitting tip of saber to something (no button held) = melt.
- Thrust forward when ON (and backward too when dual blades) = stab (air stab/running through).
- Thrust forward when OFF (and backward too when dual blades) = FastOn() ignition of the blade thrusted toward. (define BC_THRUST_ON)
How do you stop melting something?
Move the saber, like start a swing away from the area.
This modified thrust and my melt:
Actually my intended use was for Wushu Sword Drills (武术剑术)as they sometimes use a light prop sword that makes a nice “snap” during a stab. Stabs typically start at/near the hip and end with a fully extended arm, which would be around 1m throw distance. That’s why my detection works only on long/far thrust motions. I could experiment with detecting 20cm or 50cm distance stabs instead.
Maybe a shorter stabby movement could replace the current thrust, but I think EVENT_THRUST is mostly used for “thrust-on”. I don’t actually use thrust-on so I can’t say if my method is a good replacement. For longer thrusts (which I’m mapping to EFFECT_STAB) it produces less false positives which is what I was after.
Here’s a video of thrust/stab distance with the props file that I posted:
Nice! I see…it triggers a proper clash like event after a lunge. I like it, but it’s not what I was after, which is essentially a smooth swing like hum over movements that don’t involve enough rotation to trigger the algorithm.
It really is a nice substitute for a spring steel snap. I’ll load it up this weekend.
Ok I reduced the velocity/acceleration thresholds and the duration as well. This produces detection for fairly short thrusts (around 6 inches) but false positives are a bit more frequent. Here is the code I changed from the previous code post above:
// EVENT_THRUST
// start of thrust/stab motion
if (sqrt(mss.y * mss.y + mss.z * mss.z) < 15.0 &&
velocity_estimate_ > 1.0f &&
mss.x > 3 &&
fusor.swing_speed() < 130) {
thrust_begin_millis_ = millis();
// end of thrust/stab motion
velocity_estimate_ > 0.7f &&
mss.x < -3 &&
uint32_t thrust_duration = millis() - thrust_begin_millis_;
if (thrust_duration < 200 && thrust_duration > 30) {
velocity_estimate_ = 0.0f;
Event(BUTTON_NONE, EVENT_THRUST);
Also the full updated props file:
saber_fett263_custom.h (212.3 KB)
Also note that I define #define FETT263_USE_BC_MELT_STAB
in my config
Feel free to try this out and compare. Not sure what I would need to change to reduce false positives while still detecting the gestures that I want.
