Volume menu 1 button setup does not trigger
the policy I’m using is the fett263 prop and when I try to use the volume level and the prop states that pointing up or parrallel while hold pwr and clash but I’m getting a force ) can you see anything in my config that might be causing this?
LGT1Button36v5-1.h (85.0 KB)
You may be holding the button too long before clashing. A long press would trigger force. I would try to clash immediately after pressing the button.
the serial monitor results:
Battery voltage: 3.87
BatBattery voltage: 3.84
Booster off.
EVENT: Power-Pressed#1 millis=139770106
EVENT: Power-Pressed millis=139770106
No sounds found: press
Unmounting SD Card.
Amplifier off.
EVENT: Power-Held#1 millis=139770427
EVENT: Power-Held millis=139770427
EVENT: Swing mods Power millis=139770826
unit = 0 vol = 0.50, Playing Bank24/force/force1.wav
EVENT: Clash millis=139770851
EVENT: Swing millis=139770873
Ignition.
unit = 1 vol = 0.00, Playing Bank24/hum.wav
unit = 4 vol = 0.50, Playing Bank24/out.wav
humstart: 1300
unit = 3 vol = 0.00, Playing Bank24/swingl/swingl2.wav
unit = 2 vol = 0.00, Playing Bank24/swingh/swingh2.wav
EVENT: Power-Released#1 ON millis=139771981
EVENT: Power-Released ON millis=139771981
No sounds found: release
EVENT: TwistLeft ON millis=139777684
EVENT MENU TURN LEFT
Battery voltage: 3.63
EVENT: TwistRight ON millis=139791197
EVENT MENU TURN RIGHT
TWIST
EVENT: Twist ON millis=139792703
Turning off 0.00@0
Turning off 0.00@0
Turning off 0.00@0
Turning off 0.00@0
Turning off 0.00@0
unit = 0 vol = 0.50, Playing Bank24/in.wav
No sounds found: pstoff
Unmounting SD Card.
Amplifier off.
Booster off.
Battery voltage: 3.82
EVENT: TwistLeft millis=139815288
EVENT: Clash millis=139818967
EVENT: Clash millis=139823627
Battery voltage: 3.83
in this case it was held and clashed but it turned on.
on volume menu but no sound came out.
Yeah, your clash is registering after the long hold, needs to be clashed sooner.
so I figured it out, it’s volume level on the blade. so the common doesn’t sound it’s visual.
lol.
