Hello There. Looking for some help. Having volume issues with my build. i went as far as changing out the speakers, wires, and even the board and the volume is extremely low. Volume in the config is set to 2000. Running SO Darkside 4OM speakers. any help is appreciated.
Did you use Volume Menu to increase to maximum?
Do you have #define BOOT_VOLUME in your config?
If you open Serial Monitor and send get_volume
what does it say?
That’s exactly what the issue was. Haha. Completely worked. Thanks!
What is exactly what the issue was? You hadn’t tried just turning it up?
