Hi everyone! Brand new member with a bit of a headache. I’ve been doing builds with Plecter boards since 2015, but this is my first ever Proffieboard install. I was really nervous about having to program the board, but everything actually went much more smoothly than anticipated, however -
I installed the latest version of ProffieOS from fredrik.hubbe.net and everything is working except that the sound is barely perceptible (if I put my ear right up to the speaker, I can barely hear it).
Nothing looks odd in the serial monitor. All the font sounds are activating properly. There are no error messages popping up during swings, clashes, etc. The neopixels are activating properly.
When I do a get_volume, it reports the volume is at 1000. I tried bumping it up to 1500 in the config file just to see if that would make any difference and it didn’t.
I also verified that I have 5v between GND and 5V and then I tried using another speaker. No change.
As a last resort, I grabbed a build of ProffieOS from github and installed that. No difference. Everything works except the volume.
I’ve run out of ideas. Anything else I should check?
