Hi all, hoping somebody can help me figure out a weird issue. I recently purchased an Ultimate Works Crossguard(Kylo Ren) during their Black Friday deal. The past couple days I’ve been working on getting the config set up. The config setup hasn’t been an issue and I’ve been able to get new bladestyles and soundsfonts loaded. This isn’t my first proffie lightsaber but it is the first one with a crystal chamber.
The issue: All blades work fine except for the crystal chamber after turning off main blade. The crystal chamber does the off behavior as dictated in the style code for only a few seconds and then goes really dim. This only seems to happen after the main blades have been ignited and turned off. When booting the lightsaber for the first time without igniting the blades, the crystal chamber does the heart beat animation and never goes dim. Seems like turning off the main blades seems to cut power to the leds in the crystal chamber after a few seconds? I can’t figure it out and hoping somebody with more experience can take a look.
Here is my config: KR_UW_DMTv2 - Pastebin.com
I did simple color styles to identify the blades. Here is what I found in case it helps:
130 pixel blade: Main blade
30 pixel blade: 2 side blades. Seems both light on this one declaration
9 pixel blade: Crystal chamber
8 pixel blade: Bottom pummel accent
The 2 other blade declarations I couldn’t figure out at first. However, removing them from the config ends up getting a single blue led to show in the crystal chamber area. So it seems those 2 might be single leds used in the chamber area but not 100% positive as I only see the blue one.
Any thoughts or ideas? Really stumped on this as the style code seems to work fine during initial boot and for a few seconds after blade retraction.
