Using master OS for blade ID and some pixels will not animate while blades are off
I am working on a master chassis that changes when inserted into different emitters using blade ID. The accent pixels on the chassis are not animating while the blades are “off” but the board is powered on. They are just frozen or bugging out with odd colors.
I have tried different code and get the same results. I am leaning towards a bug in the Master.
This code is confirmed working with OS7.14 but I cannot get Blade ID to work correctly with the stable OS.
Is blade ID supposed to be working on OS7.14 with the defines for how frequently it checks the line?
I have tested on multiple sabers with the same code and went back and forth testing on OS7.14 and the master.
Blade ID is working great with the masterOS.
Here is my config for good measure.
I appreciate any help/feedback!
#define NUM_BLADES 8
#define VOLUME 2500
const unsigned int maxLedsPerStrip = 180;
#define CLASH_THRESHOLD_G 3.5
#define ENABLE_SSD1306
#define SAVE_STATE
#define BC_TWIST_ON
#define BC_TWIST_OFF
#define BC_NO_BM
#define BC_LOCKUP_DELAY (200)
//    Use with Blade ID. Specify the LED pad(s) that the main blade uses.
#define ENABLE_POWER_FOR_ID PowerPINS<bladePowerPin4,bladePowerPin5>
//    Required when blades on different data pads use common LED power pads.
//    and/or when BLADE_ID_SCAN_MILLIS is used with Blade ID.
#define SHARED_POWER_PINS
//    Choose how often to check for new blade (milliseconds).
//    Larger values will be a longer delay before a blade is recognized.
//    How many Blade ID scans to average (default is 10, 15 works well)
#define BLADE_ID_TIMES 15
//    Measured value range to return as NO_BLADE (use NO_BLADE as the blade definition value.)
#define NO_BLADE_ID_RANGE 600000,999999999
#include "../props/saber_BC_buttons.h"
Preset standard[] = {
{ "Blue;common", "/common/tracks",
  //Emitter
StylePtr<Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,
  TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,White>>,TrFade<1200>>,EFFECT_IGNITION>,
  LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrColorCycleX<BendTimePowInvX<IgnitionTime<1500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>,100,1000>,TrColorCycleX<BendTimePowInvX<RetractionTime<1000>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>,1000,100>,ColorCycle<RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,25,50,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,25,1500,4000>>>>(),
  //Blade
StylePtr<Layers<
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
  LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,White>,TrFade<400>>>,
  LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,19992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,6992>,Int<98304>>>>>>>(),
  //plasma gate
StylePtr<Layers<
  TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<BLAST_COLOR_ARG,White>,TrFade<300>>,EFFECT_BLAST>,
  TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,White>,TrFade<300>>,EFFECT_CLASH>,
  LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,50,1>,Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
  InOutTrL<TrConcat<TrFadeX<BendTimePowInvX<IgnitionTime<1500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,Red,TrFadeX<BendTimePowInvX<IgnitionTime<1500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,DarkOrange,TrFadeX<BendTimePowInvX<IgnitionTime<1500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,White,TrFadeX<BendTimePowInvX<IgnitionTime<1500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>>,TrConcat<TrFadeX<BendTimePowInvX<RetractionTime<1000>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,White,TrFadeX<BendTimePowInvX<RetractionTime<1000>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,DarkOrange,TrFadeX<BendTimePowInvX<RetractionTime<1000>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Red,TrFadeX<BendTimePowInvX<RetractionTime<1000>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>,ColorCycle<RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,25,50,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,25,1500,4000>>>>(),
//crystal
StylePtr<Layers<
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Int<0>>,EFFECT_BLAST>,
  InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,8000>>>>(),
//Back
StylePtr<Layers<
  Stripes<5000,-2500,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,255>>>,
  InOutTrL<TrFadeX<BendTimePowInvX<IgnitionTime<500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<500>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BLAST_COLOR_ARG,Rgb<180,190,200>>,2000>>>>(),
  //crystal
StylePtr<Layers<
//motor
  StyleNormalPtr<Rgb<200,0,0>,WHITE,300,800>(),
  //Xguard
StylePtr<Black>(),
"blue"},
Preset crossguard[] = {
{ "Blue Crossguard;common", "/common/tracks",
  //Emitter
StylePtr<Layers<
  //Blade
StylePtr<Layers<
  //plasma gate
StylePtr<Layers<
//crystal
StylePtr<Layers<
//Back
StylePtr<Layers<
  //crystal
StylePtr<Layers<
//motor
  //Xguard
StylePtr<IgnitionDelayX<Int<1000>,Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,200>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,200>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,200>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,80,200>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,200>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,80,200>>>,
  InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<200>,Mult<IntArg<IGNITION_OPTION2_ARG,20992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,7992>,Int<98304>>>>>>>>(),
    "blue"},
Preset noblade[] = {
{ "Calibrate1;common", "/common/tracks",
  //Emitter
StylePtr<Black>(),
  //Blade
StylePtr<Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Black>,RgbArg<BASE_COLOR_ARG,Black>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Black>>,RgbArg<BASE_COLOR_ARG,Black>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Black>>>,RgbArg<BASE_COLOR_ARG,Black>>,RgbArg<BASE_COLOR_ARG,Black>>,
  Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BASE_COLOR_ARG,Black>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<BASE_COLOR_ARG,Black>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
  LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<BASE_COLOR_ARG,Black>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Black>>>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Black>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Black>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<BASE_COLOR_ARG,Black>,Mix<Int<20000>,Black,RgbArg<BASE_COLOR_ARG,Black>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<BASE_COLOR_ARG,Black>,AlphaL<RgbArg<BASE_COLOR_ARG,Black>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<BASE_COLOR_ARG,Black>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<BASE_COLOR_ARG,Black>>,BrownNoiseFlickerL<RgbArg<BASE_COLOR_ARG,Black>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<BASE_COLOR_ARG,Black>,RotateColorsX<Int<3000>,RgbArg<BASE_COLOR_ARG,Black>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<BASE_COLOR_ARG,Black>,RotateColorsX<Int<3000>,RgbArg<BASE_COLOR_ARG,Black>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<BASE_COLOR_ARG,Black>,RotateColorsX<Int<3000>,RgbArg<BASE_COLOR_ARG,Black>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<BASE_COLOR_ARG,Black>,RotateColorsX<Int<3000>,RgbArg<BASE_COLOR_ARG,Black>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<BASE_COLOR_ARG,Black>,RotateColorsX<Int<3000>,RgbArg<BASE_COLOR_ARG,Black>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>>>>(),
  //plasma gate
StylePtr<Layers<
  Pulsing<Mix<Int<8192>,Black,RgbArg<BASE_COLOR_ARG,Rgb<180,190,200>>>,RgbArg<BASE_COLOR_ARG,Rgb<180,190,200>>,2000>,
  TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<ALT_COLOR2_ARG,Red>,TrFade<300>>,EFFECT_BLAST>,
  TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<ALT_COLOR2_ARG,Red>,TrFade<300>>,EFFECT_CLASH>,
  LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<ALT_COLOR2_ARG,Red>,AudioFlicker<RgbArg<ALT_COLOR2_ARG,Red>,Blue>,50,1>,50,1>,Strobe<RgbArg<ALT_COLOR2_ARG,Red>,AudioFlicker<RgbArg<ALT_COLOR2_ARG,Red>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
  InOutTrL<TrColorCycleX<BendTimePowInvX<IgnitionTime<1500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>,50,1500>,TrColorCycleX<BendTimePowInvX<RetractionTime<1000>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>,1500,50>,ColorCycle<RgbArg<BASE_COLOR_ARG,Rgb<180,190,200>>,25,50,RgbArg<BASE_COLOR_ARG,Rgb<180,190,200>>,25,1500,4000>>>>(),
//crystal
StylePtr<Layers<
//Back
StylePtr<Layers<
  InOutTrL<TrFadeX<BendTimePowInvX<IgnitionTime<500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<500>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Rgb<180,190,200>>,2000>>>>(),
  //crystal
StylePtr<Layers<
//motor
  //Xguard
StylePtr<Black>(),
"blue"},
 { NO_BLADE,
  //Emitter
 SubBlade(0, 15, WS281XBladePtr<171, bladePin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >()),
  //Blade
    SubBlade(16, 170, NULL),
  //Plasme Gate
  WS281XBladePtr<20, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
  //CRYSTAL
  WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2> >(),
  //Back
  SubBlade(0, 9, WS281XBladePtr<22, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin3> >()),
  //Crystal2
      SubBlade(10, 10, NULL),
  //Motor
  SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(),
  //Xguard
  WS281XBladePtr<24, blade6Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >(),
     CONFIGARRAY(noblade) },
 { 10602, // Needs to be obtained by running `scanid` in Serial Monitor with blade inserted. Enter average, rounded value.
  //Emitter
  //Blade
  //Plasme Gate
  //CRYSTAL
  //Back
  //Crystal2
  //Motor
  //Xguard
     CONFIGARRAY(standard) },
 { 32775, // Needs to be obtained by running `scanid` in Serial Monitor with blade inserted. Enter average, rounded value.
  //Emitter
  //Blade
  //Plasme Gate
  //CRYSTAL
  //Back
  //Crystal2
  //Motor
  //Xguard
     CONFIGARRAY(crossguard) },
Which accent pixels? I’m not sure which ones are “on the chassis”.
And when you say “while the blades are off”, do you mean it’s in the NO_BLADE state, or do you mean that the blades are just not ignited?
No.
So I would say all of the pixels are acting funny while the blades are not ignited.
The pixels on the chassis are:
Plasma Gate - data 4, power pin 1
Crystal - data 2, power pin 2
Back - data 3, power pin 3
Crystal 2 - sub blade of “Back”
all other pixels are either not doing anything while the saber is not ignited or are not immediately visible as they are in the emitter and not attached to the chassis.
simple pulsing just stays static.
When the saber is ignited, it seems that the animations look normal.
I wonder if it’s power or data that is not working.
Have you tried measuring to see if these pixels have proper input power when they are not working? Or maybe just short LED1 to BATT- and see if the plasma gate starts behaving?
It sounds like the sort of thing that happens when SHARED_POWER_PINS is missing, but I see that in your config, so that shouldn’t be the problem.
So I am merely taking care of the config. The chassis is not in my possession. I am helping Goth-3Designs with the programming for this saber.
Seeing as he is located in France… This might take a little back and forth.
I will ask him to try this and report back tomorrow with his findings!
Okay,
I have asked Rick to take a video of the sabers and demo them both with OS7.14 and the Master so you can see whats going on because everything lights up evenly. You can see everything lit up brightly but are static with the Master.
here is a link to the Standard saber.
here is the blade config:
STANDARD SABER
  //Emitter
  //Blade
  //Plasme Gate
  //CRYSTAL
  //Back
  //Crystal2
  //Motor
  //Xguard
Here is a link to the Shoto:
Here is the Blade config:
SHOTO SABER
  //Emitter
 { 0,    SubBlade(0, 15, WS281XBladePtr<140, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
  //Blade
    SubBlade(16, 139, NULL),
  //Crystal
  WS281XBladePtr<1, blade5Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
  //Front Strips
  WS281XBladePtr<10, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(),
  //Back Strip
  WS281XBladePtr<8, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
CONFIGARRAY(presets) },
Any ideas? :sweat_smile:
One possibility is that this is a save directory problem.
presets.ini/tmp refer to the preset array, and when you have different preset arrays for different blade IDs that can cause a bunch of problems.
There are two possible solutions:
  1. use the same, or mostly identical preset arrays for each blade ID entry. (They must have the same number of entries at the very least.)
  2. Specify separate save directories for each blade ID after the CONFIGARRAY() (One can be left without a save directory, so that it will still save to the root directory of the SD card.)
Only one of the two sabers is using blade ID. The Shoto is not using the blade ID at all and is having the same lighting issues with the same config between OS 7.14 and the master.
The saber that IS using Blade ID, the preset arrays are all identical.
Can you post the full config for the non-blade-id one?
#define NUM_BLADES 5
#define VOLUME 2500
#define SAVE_STATE
#define BC_TWIST_ON
#define BC_NO_BM
  //Emitter
StylePtr<Layers<
  //Blade
StylePtr<Layers<
//crystal
StylePtr<Layers<
  //Front
StylePtr<Layers<
//Back
StylePtr<Layers<
"blue"},
  //Emitter
  //Blade
  //Crystal
  //Front Strips
  //Back Strip
So it’s the “color when off” part that’s not right? And in this case that’s using ColorCycle for that, right?
The only change I can see to ColorCycle itself since Feb4 (7.14 release date) is that some variable names changed, but maybe something else too?
I put the “//Front” style on for my blade emitter and it’s doing what it’s supposed to with the GitHub Master (slowly clycling), so I’m lost why you have a static lit LED.
That’s what’s happening, yes?
Correct. For some reason with the master, the majority of pixels become static while the blade is off but power is supplied to the board.
Does the problem move if you change the styles around?
In other words, if the accent LEDs on data3 are weird, what if you swap the main blade style with it to test?
Trying to determine if it’s a style template issue, or something more hardware based.
Hey,
I just did the swap you suggested (swap the style between data3 and data4).
Data3 was working fine, but Data4 was with that static issue
after swapping, it’s now Data3 with the static issue, while Data4 is fine.
The blade style not working is:
//Back
StylePtr<Layers<
The one working is:
  //plasma gate
StylePtr<Layers<
What version of arduino-proffieboard are you using?
I took the OS here for the last test:
and the software version is Arduino 1.8.4 with this Proffieboard version
Let me know if that is the info you wanted :slight_smile:
It’s the Pulsing that’s the issue.
PulsingL works fine.
@profezzorn It’s this commit that hinders Pulsing from working as color when off in an InOutTrL.
Interesting, how did you find out?
(I’ll see if I can figure out how to fix it…)
