Understanding SNV4 Pro 2 - coding Blade Styles
HI all, i just got my first SNV4 Pro saber and I’ve been trying to adapt some Fett263’s styles.
And it seems the chip doesn’t read live changing values like BladeAngle, TwistAngle, SwingAcceleration.
Any time I use those it just bakes in a looped animation or it doesn’t work.
However, SwingSpeed seems to be supported and it uses this line:
Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Int<12345>,Int<0>>
This can be used to trigger a layer, but when I change the SwingSpeed value it’s doesn’t seem to have an effect.
I’m trying to understand how it works, is it just baked in to work a certain way and there is no way around it?
You’re in the wrong place, SNV is not Open Source and has nothing to do with those of us here. You’ll have to ask the maker of that board.
If you actually want to use Proffieboard styles I’d recommend getting an actual Proffieboard, then we’re more than happy to help ;-).
whoops, sorry.
Anyhow, 3.9 is on the way :wink: so I’m just trying to do the best I can with this one. I’ll send them a message thanks
No worries, when your Proffieboard arrives feel free to pop back in. Good luck.
