"Twist" sound font not working?
I just finished my first custom Proffie build. At first it looks like everything is working but the twist sounds don’t play.
I tried to find for similar issues, but couldn’t find them here. I’ve already checked the gyro and that seems fine to me.
What’s happening:
When I tilt the blade up or down I hear the swing sounds.
When I twist the blade left or right, i don’t hear any swing/twist sounds.
I looked at the Serial Monitor and see “EVENT MENU TURN RIGHT” or “EVENT MENU TURN LEFT”. This also tells me the gyro works fine.
I loaded a Xenopixel variant of the same font on my Xenopixel saber, and this one does play the ‘twist’ fonts.
Am I missing something here?
I’m using ProffieOS 7.15 with a Fett263 modified config
What’s a twist sound? Twist is just a control it doesn’t have a sound dedicated to it.
Maybe it’s just something that a Xenopixel has and the Proffie board doesn’t.
But if I slowly twist the hilt left and right on the Xeno, some of the swing sounds are played.
Yeah, that’s not a thing on Proffieboard.
Alright, check!
Thanks for the quick help.
It should maybe be pointed out that this behavior is intentional. Twisting doesn’t cause the blade to move through the air, which is presumably what make noises. For this reason, ProffieOS uses the y and z rotational axis to calculate swing, but ignores the x rotational axis.
