True Charge Detection for Use with Custom Presets w/ or w/out Blade ID!
After not finding anything that really did what I needed, I’ve done some work on charge detection and wanted to share - hoping it will be considered for a future version of the OS.
’ve added a CHARGE_DETECT_PIN feature to ProffieOS that acts like a virtual button, similar to BLADE_DETECT_PIN, to detect when a saber is actively charging. It works with modules like the TP4056 or any other Li-Ion charger that provides a logic-level output when charging.
You can also use the built-in charger detection on Proffieboards or better (safer and better chargin) a pin that goes low when charging on an external charge module. This would be connected to any free pin and defined in your config file.
In my_config.h:
#define CHARGE_DETECT_PIN CHARGER_MONITOR  // pin 20 is CHARGER_MONITOR
Just add that or your actual charge detect pin from the external source once this logic updates I provide below are in place.
Key Benefits:
  • Lets users define a pin to trigger CHARGE_MODE.
  • Automatically switches to a dedicated preset bank when charging.
  • Integrates cleanly alongside existing blade detection logic including blade ID — still functions.
Example Presets and Blade Config
Preset definition:
Preset charge_detect_presets[] = {
  { "ChargeFont;common", "",
    StylePtr<Black>(),  // Main blade off
    StylePtr<Layers<
      Mix<
        SmoothStep<Scale<BatteryLevel, Int<0>, Int<32768>>, Int<1>>,
        Mix<BatteryLevel, Red, Green>,
        Black
    >>(),  // Pixel switch or secondary blade
    "Charging"
Blade config entry:
{ CHARGE_MODE,
  WS281XBladePtr<16, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>(),
  WS281XBladePtr<6, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4>>(),
  CONFIGARRAY(charge_detect_presets), "charge_save"
Since CHARGE_MODE is defined as 2000000000, it always ranks higher than NO_BLADE or any blade ID.
Code Changes (by file and location)
ProffieOS.ino – In Warmup() block (above BladeDetect.Warmup):
#ifdef CHARGE_DETECT_PIN
  ChargeDetect.Warmup();
ProffieOS.ino – Register virtual button (below BladeDetect):
LatchingButtonTemplate<FloatingButtonBase<CHARGE_DETECT_PIN>>
    ChargeDetect(BUTTON_CHARGE_DETECT, CHARGE_DETECT_PIN, "charge_detect");
events.h – Below BUTTON_BLADE_DETECT:
BUTTON_CHARGE_DETECT = 2048,
events.h – Below NO_BLADE:
#define CHARGE_MODE 2000000000 /* 2 billion */
prop_base.h – Near blade_detected_ flag:
  bool charge_detected_ = false;
prop_base.h – Inside id() before blade_detected_ section:
STDOUT << "CHARGE PIN READ: " << digitalRead(CHARGE_DETECT_PIN) << "\n";
  if (charge_detected_) {
    STDOUT << "CHARGING\n";
    ret += CHARGE_MODE;
  } else
saber_fett263_buttons.h – Before BLADE_DETECT_PIN section:
  case EVENTID(BUTTON_CHARGE_DETECT, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_ON):
  case EVENTID(BUTTON_CHARGE_DETECT, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_OFF):
    charge_detected_ = true;
    FindBladeAgain();
    return true;
  case EVENTID(BUTTON_CHARGE_DETECT, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_ON):
  case EVENTID(BUTTON_CHARGE_DETECT, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_OFF):
    FindBladeAgain();
    return true;
I’ve tested this on a Proffie v3.9 using a TP4056 module. Works smoothly with no conflicts. Screenshots of the changes are attached for reference.
If you have any questions or need more information, please let me know. I’m looking into making this a patch and will be doing the same for OS8 assuming it doesn’t make the cut yet.
Thanks!
Interesting.
Some hilts already use 2b as a chassis-has-been-removed-from-hilt mode.
Maybe make this 900m instead.
Good to know! Thank you.
Just a quick follow-up and correction to my original post:
While the Proffieboard V3 does support USB charging at a low current (~450mA), the VBUS line (pin 20) can’t be read in firmware — it’s not connected to a GPIO. That means it can’t be used directly for charge detection as I had suggested.
The most reliable approach is still what I’ve implemented: using a separate charge module with its own dedicated charge detect line wired to a GPIO. I have my charge detect line wired to pin 7, defined like this:
#define CHARGE_DETECT_PIN 7
I also implemented profezzorn’s recommendation for the value for CHARGE_MODE in the events.h file:
#define CHARGE_MODE 900000000 /* 900 Million */
Is there more info on this removal mode? That sounds super interesting.
There should be some threads around here about it, but it might require some spelunking, because the first two searches I tried did not find it.
Same. Couldn’t find it yet.
This topic got my brain going and I think I’ve come up with another solution to trigger charging detection. Same benefits as before but with a smaller (6mm square) add on board, I’ll include links below for the parts needed. There will still need to be the usual stuff added in the config for Blade ID to work of course
##Key Benefits:
###How it works
Once the USB port is connected it’ll activate the mosfet and deliver the negative voltage to the Free 1 pad and activate the change of presets.
####Wiring
The wiring would be fairly simple on this
USB + goes to mosfet Gate (1) and Proffie V3 VUSB pad
USB - goes to mosfet Source (2) and Proffie V3 GND pad
USB D+ goes to Proffie V3 D+ pad
USB D- goes to Proffie V3 D- pad
Mosfet Drain (3) goes to Proffie V3 Free 1 pad
#####Part links
Profezzorn oshpark link
https://oshpark.com/profiles/hubbe
N- Channel mosfet
https://www.mouser.com/ProductDetail/Vishay-Siliconix/SI2302CDS-T1-BE3?qs=CiayqK2gdcKmknxSqRbb7w%3D%3D
100K Ohm resistor
https://www.mouser.com/ProductDetail/71-RCG0603100KJNEA
Hey there! This is a super clean method of grabbing the low signal needed for charge detect. Nicely done! I wanted to charge separate from the board to give faster charging rather than the trickle available on the v3.9 so that’s why I used the USB Charge Port available on a lot of lightsaber parts sites like this one from TCS:
https://www.thecustomsabershop.com/Electronics/Batteries-and-Packs/Clips-Connectors/USB-C-Charge-Port
The biggest challenge on this one was determining how to get the charge detect low signal I wanted. I have since found that connecting to pin 7 on the TP4056 gives a clean signal while actually charging rather than just plugged in and comes in a pretty small package. It’s still not exactly how I want it though for ease of use - especially because I like to also have data lines on my USB connector so end up with an additional module on top if this. I’m in the process of a new design to address all that which I’ll post here when complete for anyone who wants it. Still, hard to beat your 6mm square package solution.
Here’s some small tp4056 breakout boards on oshpark that could work. You’d have to solder directly to the pins for the signals and use the usual data pads on the v3 for data. I love it when creators share their pcb designs on oshpark, super helpful
https://oshpark.com/profiles/mzst
I have since outgrown this method and created a new one that I think works much better, does not require any source code modification, and is built around an unmodified Fett263 prop set up. If there is interest, I will create a post sooner than later.
There is interest.
Ok post coming soon!
