Finished my first build with a kit from the Saber Armory (proffie v3.9), and the power button doesn’t work. I’ve changed proffie config to a 1 button setup like this:
And the saber powers on and looks good. I used a multimeter and can see there’s basic connectivity to M and F rotary connectors, how can I test more extensively?
No, power button is still failing. I checked again and I can’t see a connection between the female rotary connector and the power button, which unfortunately I had to glue in place as it wouldn’t sit normally. Will see if I can get it off with acetone.
OK, got it working – I hadn’t seen this before, but the switch had one leg that was permanently on unless pressed, and the other was off unless pressed.
