Trouble getting config to verify
I’m just starting out in the hobby and having some trouble getting my config file to verify. Any ideas about what the issue could be?
Thanks!
#define NUM_BLADES 2
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
    StylePtr<Layers<StaticFire<BrownNoiseFlicker<Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,RandomPerLEDFlicker<Mix<Int<3213>,Black,Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>>,Mix<Int<7710>,Black,Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>>>,300>,Mix<Int<10280>,Black,Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>>,0,6,10,1000,2>,TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<1000>>,Int<300>,Int<3000>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,255>>,Int<0>>,TrSparkX<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,255>>,Scale<NoisySoundLevel,Int<200>,Int<600>>,Int<250>,Int<0>>>>,AlphaL<RandomPerLEDFlickerL<RgbArg<EMITTER_COLOR_ARG,Rgb<0,0,255>>>,SmoothStep<Scale<NoisySoundLevel,IntArg<EMITTER_SIZE_ARG,-818>,Sum<IntArg<EMITTER_SIZE_ARG,-818>,Int<6000>>>,Int<-6000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<200>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<EMITTER_SIZE_ARG,-818>,Int<-500>>>,TrFade<300>,AlphaL<Blue,SmoothStep<IntArg<EMITTER_SIZE_ARG,-818>,Int<-500>>>,TrFade<500>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<400>>,TrInstant>,Stripes<5000,2500,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<0,0,255>>>>,TrFade<800>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Scale<ClashImpactF<>,Int<100>,Int<600>>>,TrCenterWipeX<Int<150>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-10000>>>>>,AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-10000>>>>,StripesX<Int<16000>,Scale<ClashImpactF<>,Int<3000>,Int<10000>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,20,128>,Rgb<128,0,0>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,DodgerBlue,Red>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,10,80>,Rgb<90,0,0>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<50000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,EFFECT_CLASH>,LockupTrL<AlphaL<StripesX<Int<16000>,Int<12000>,Rgb<128,0,0>,Red,Rgb<90,0,0>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-10000>>>,Int<50000>>>,TrConcat<TrJoin<TrDelayX<Scale<ClashImpactF<>,Int<2000>,Int<100>>>,TrCenterWipeX<Int<150>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-10000>>>>>,AlphaL<StripesX<Int<16000>,Scale<ClashImpactF<>,Int<3000>,Int<10000>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,20,128>,Rgb<128,0,0>>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,DodgerBlue,Red>,Mix<IsGreaterThan<ClashImpactF<>,Int<23000>>,Rgb<0,10,80>,Rgb<90,0,0>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,23243>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<50000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<600>,Int<100>>>>,TrFade<400>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<0,0,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<30,60,200>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30502>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<30,60,200>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,30502>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28945>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28945>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28945>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrJoin<TrDelayX<Mult<IgnitionTime<1100>,Int<16384>>>,TrWipeX<Mult<IgnitionTime<1100>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<0,0,255>>>,TrWipeX<Mult<IgnitionTime<1100>,Int<16384>>>>,TrConcat<TrSparkX<Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,Int<100>,Mult<RetractionTime<400>,Int<6554>>,Int<0>>,AlphaL<Black,SmoothStep<Int<26216>,Int<0>>>,TrSparkX<Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,Int<100>,Mult<RetractionTime<400>,Int<6554>>,Int<0>>,AlphaL<Black,SmoothStep<Int<19662>,Int<0>>>,TrSparkX<Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,Int<100>,Mult<RetractionTime<400>,Int<6554>>,Int<0>>,AlphaL<Black,SmoothStep<Int<13108>,Int<0>>>,TrSparkX<Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,Int<100>,Mult<RetractionTime<400>,Int<6554>>,Int<0>>,AlphaL<Black,SmoothStep<Int<6554>,Int<0>>>,TrSparkX<Gradient<RotateColorsX<Scale<Sin<Int<45>>,Int<0>,Int<3313>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>,RotateColorsX<Scale<Sin<Int<45>>,Int<3313>,Int<0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,97,0>>>>,Int<100>,Mult<RetractionTime<400>,Int<6554>>,Int<0>>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,-818>,Int<-4000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,-818>,Int<-4000>>>,TrFade<300>>,EFFECT_BOOT>>>(),}
    &style_charging,
{ 0, WS281XBladePtr<105, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<1, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>(),
SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin5, -1, -1, -1>(),
SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(),
CONFIGARRAY(presets) },
What error do you get?
First preset is missing a comma after it.
Also missing a nice “name” argument.
Presets should end like
.......>(), "preset name here"},
The comma at the end is important because another element follows it (the next preset).
IF it were the last preset which is followed by the array closing brace } you would not need a comma because nothing follows.
Anyway, also, you have
NUM_BLADES 2
1 or 2 styles in your presets,
and 5 blades in the BladeConfig.
They all need to match quanity.
If you have 5 actual wired blades, (switch button LED, accent LEDs etc…) You need to account for them in NUM_BLADES, as well as have a blade style for each of them.
You may find this tool helpful, just watch the video and read through the selections and it will handle the syntax for you, you’ll just need the BladeConfig section from your installer’s original config as this tells us how it’s wired.
Thank you! I will take a look at that. I’m very bad at coding so that is greatly appreciated.
