EDITED TO ADD: Tried editing based on the configurator, then nothing lit up, lol. I’ve found a few of the styles that seem to work and I can probably tweak those to get them to flash the blade the way I want it to. The adapter seems to behave like it’s just the base LED in the string (based on how effects seem to work or not).
Original Post Below:
A coupla three years ago, I got my hands dirty and did some serious digging into Proffie stuff and got things all setup nice, no small thanks to folks here. Put some fancy profiles and fonts on there, lots of fun. And then I didn’t touch a damn thing for 3 years. It all worked how I wanted, so why bother, yanno? Problem is now I wan to change things again, so I’m /basically/ starting from scratch again. My questions are /probably/ super basic.
I’m also trying to setup my hilt for baselit / sparring, so switching from a Neopixel blade to one of these guys: Tri Cree LED Adapter Standard – Crimson Dawn®
On the plus side, for several of my fonts, it works / looks fine - for several others, however, it’s a mess. Everything from just the wrong color to strange flickering, etc.
I’m assuming I probably need to go poke around in Arduino proper and (using the configurator) update my config for the different type of “blade”, yes? I vaguely remember having the wrong number of LEDs set on the neopixel making for some fun times.
Or can I cheat and just use the web workbench (https://profezzorn.github.io/lightsaber-web-bluetooth/app.html) and change stuff up there?
