Tracks not playing
appolgy for the screen,
i did put the sound file in audacity and use the setting fett sugested.
after that came the error above
Inhave got the track working only the font left
For future reference, and to not have to run files through Audacity w/ all that hassle, you can use Brian Connor’s excellent sound font converter.
It’ll convert between different board conventions, but it’ll (most importantly for this case) also ensure all the audio files are in correct format. You can also run just track files through it.
https://www.soundfontnamingconverter.com/
^^^ this. You could use the audio conversion only option at the top, but might as well optimize your font hierarchy and naming while your at it. Just choose Proffie to Proffie, choose the font folder to upload, convert, then download the result. Unzip and replace your font on the SD card.
