Time Triggers for Sound Files
I’ve been looking through the documentation on the OS and, perhaps I missed it, but is there a way to set a timing trigger to auto-initiate playing audio files?
For example, lets say I want to play a quote every 5 minutes, is there a way I can script that to run without me having to use the button commands to play the file?
You could try this, but you need a prop that supports quotes.
TransitionLoopL<TrConcat<TrDoEffect<TrInstant,EFFECT_QUOTE>,TrDelay<3000000>>>
This (and almost anything you can imagine) can be done by writing some C++ code, in most cases that means modifying a prop file, but there are lots of other ways to do it as well.
Could you not just make a quote track with them spaced five minutes apart? Unless I’m missing your intent somehow.
That’s one of the lots of ways :wink:
Or you could put it in the hum file(s).
(Either one 5-minute hum file with the sound mixed in somewhere, or 5 one-minute hum files with the sound mixed into one of them.)
Got a couple of fonts like that, too, Prof. And there for a minute, I got into overlaying quotes into tracks. Fun stuff, Audacity.
Ahsoka/Mando Track
