Minor Spoiler for The Acolyte -
Cortosis is a rare metal that can disrupt and short out the blade of a lightsaber and render it temporarily disabled.
I have built a brand new Special Ability into my Early Access OS7 Style Library that replicates the battle with the Stranger in the Acolyte Series.
When a lightsaber blade strikes Cortosis the blade is disrupted and the saber is shorted out rendering it disabled for a period time. This is used to great advantage by the Stranger.
With the new “Cortosis Clash Mode” Special Ability in my Early Access Library you can replicate this effect. Using the Special Ability of your choice you can enter Cortosis Clash mode for a period of time, while in this mode the next clash that occurs within that time (Delay) will replicate the effect of clashing against Cortosis and your saber will short out and be temporarily disabled from igniting using the Power Button. After the Time for the Cortosis effect runs out your saber will be able to ignite and run normally again until you decide to use “Cortosis Clash” again.
This new effect uses two unique Transition Sounds, the first is to signify entering Cortosis Clash mode and the second is the disabled ignition or shorting out sound if you try to reignite after the Cortosis shorted the blade. The exact sound file name will be generated by the library in the Style Information based on the selections you make. Be sure to review so you can properly set up the sounds.
If not already an Early Access Patron be sure to sign up for access the the Early Access Library to get the new code.
For my Early Access Patrons check out the new Acolyte styles and Cortosis Clash Special Ability here:
