Weird glitchy behavior I assume is power related?
Config:
// This is a sample configuration file.
// This saber has:
// o TeensySaber V3 hardware.
// o Two buttons
// o An XP-E2 RGB LED star.
// If you have a saber similar to this one, make a copy and use the copy.
// This is also the default configuration file. Pre-programmed boards will
// use this configuration file.
#include "v4_config.h"
#define VOLUME 2200
const unsigned int maxLedsPerStrip = 30;
#define CLASH_THRESHOLD_G 1.0
#define GYRO_CLASS MPU6050
{ "TeensySF", "tracks/mars.wav",
StyleStrobePtr<WHITE, Rainbow, 15, 300, 800>(), "strobe"}
{0, WS2811BladePtr<30, WS2811_GRB>(), CONFIGARRAY(presets) },
Serial Monitor:
Sdcard found..
blade= 0
WS2811 Blade with 30 leds.
Failed to open: presets.ini
Failed to open: presets.tmp
Style RAM = 216
Scanning sound font: TeensySF done
Activating polyphonic font.
Activating SmoothSwing V2
Accent Swings NOT Detected:
unit = 0 vol = 0.50, Playing TeensySF/boot.wav
Welcome to ProffieOS $Id: ce12a06a1e236b5101ec60c950530a9a4719a74d $. Type 'help' for more info.
Audio underflows: 21
Amplifier off.
I2C TRY
I2C pullups found, initializing...
Motion setup ... done.
EVENT: Aux-Pressed#1 millis=6593
EVENT: Aux-Pressed millis=6593
EVENT: Aux-Released#1 millis=6714
EVENT: Aux-Released millis=6714
EVENT: Aux-Shortclick#1 millis=6714
EVENT: Aux-Shortclick millis=6714
Style RAM = 232
DISPLAY: blue
unit = 0 vol = 0.50, Playing TeensySF/font.wav
Amplifier off.
EVENT: Power-Pressed#1 millis=10135
EVENT: Power-Pressed millis=10135
EVENT: Power-Released#1 millis=10260
EVENT: Power-Released millis=10260
EVENT: Power-Shortclick#1 millis=10260
EVENT: Power-Shortclick millis=10260
Ignition.
unit = 0 vol = 0.00, Playing TeensySF/hum01.wav
unit = 1 vol = 0.50, Playing TeensySF/out01.wav
humstart: 1890
unit = 2 vol = 0.00, Playing TeensySF/swingl02.wav
unit = 3 vol = 0.00, Playing TeensySF/swingh02.wav
Motion chip timeout, reboot motion chip!
unit = 3 vol = 0.00, Playing TeensySF/swingl07.wav
unit = 2 vol = 0.00, Playing TeensySF/swingh07.wav
Motion setup ... failed.
Battery voltage: 0.00
Motion setup ...
