System Name for Array Index Numbers?
I’m trying to integrate Blade Detect with my Array Selector such that an array named NO_BLADE gets ignored when switching array manually, but will still be switched to when Blade Detect tells it to.
But I don’t know what the system calls those index numbers.
I’ve updated my regular code from this:
    struct SabersenseArraySelector {
      static int return_value;  // Tracks current array index.
      float id() {
        return return_value;
      static void cycle() {
        return_value = (return_value + 1) % NELEM(blades);
to this:
  float id() {
    // Skip NO_BLADE array during cycling
    int num_blades = NELEM(blades);
    do {
      return_value = (return_value + 1) % num_blades;
    } while (blades[return_value].id() == NO_BLADE);
but the system is complaing that id() isn’t recogised. I also tried ‘index’ but that didn’t work either.
So does ProffieOS have a different name for those numbers?
Thanks in advance.
:slight_smile:
I think your first code block is already the same as the changed-to version.
Anyway, maybe you could just do something like:
  if (return_value == NO_BLADE) {
    return_value = (return_value + 2) % NELEM(blades);
  } else {
Oops. Sorry. Now corrected.
They are called “ohm”:
And NO_BLADE is just a number:
also, you should check if ohm is NO_BLADE or larger, so like this:
  do {
     i  = (i + 1) % num_blades;
  } while (blades[i].ohm >= NO_BLADE);
If you then set return_value to blades[i].ohm, then you can avoid having to set the ID to 0, 1, 2. etc. (Of course you’ll also need to map return_value to an index at the beginning of cycle().)
Thanks guys! This is great. :smiley:
I’ve added your solution, Prof, and it’s working well, but I don’t have a Blade Detect hilt to test it fully. The good news is I have one on the bench that will have have BD and should be finished shortly. As soon as I’ve tested all aspects, I’ll update my prop and submit a PR to include the new Array Selector/Blade Detect functionality.
Thanks again. :pray: :slight_smile:
