Most of my sabers have the power button at the top and aux at the bottom, but I have a couple that are the opposite. can I just switch this by changing the button part of the config?
You can go on the post that solved your problem, click the “triple dots” at the bottom of that post, there is where I think you should see the solved “button” or “mark as solved”
“Solved” is only present in some areas of the forum.
This thread was posted without attaching it to any specific area, so the “solved” button is not available.
