Hi.
I have 3 Soundfonts an Bladestyles on my SD-Card. Is it possible to select them (Board V2.2) with pushing a button. Since i am starting from scratch i have button 1 and 2 on the board installed.
I have the MYFETT263CONFIG.h 2-button running.
thx
Andreas
Sound Fonts you can have as many as you want on the SD card.
Blade Styles go in the config.h and can be configured differently depending on what you want them to do.
If your config is setup to use EDIT MODE, you can dynamically customize and set the colors and style options (if the style supports it) as well as the sound font used for each style. You can make as many combinations or variations as you want.
To know more about how to help you, we’d need to see the contents of “MYFETT263CONFIG.h”. Can you post it in the topic, surrounded by ``` at beginning and end?
That’s how it always works.
Thank you. Is the Edit mode active within this config?
Andreas
#define VOLUME 100
#define CLASH_THRESHOLD_G 3.5
#define FETT263_STAB_ON
#define FETT263_THRUST_ON
#define FETT263_TWIST_ON
#define FETT263_FORCE_PUSH
{ "ESB", ";common/tracks/Wampa.wav",
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<AudioFlicker<DeepSkyBlue,SteelBlue>,White,200,100,400>,Pulsing<Gradient<AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>>,Gradient<AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>>,3500>,AudioFlicker<White,DeepSkyBlue>>,White,40>,180,500,Black>>()},
{ "FatherESB", ";common/tracks/Bespinsc.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
{ "Father", ";common/tracks/bespinpreon.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},
No, this config does not have Edit Mode and the style code is pre-OS6 so it won’t work with Edit Mode. I suggest reviewing this page.
And use this tool to customize your config, it will make customization and set up much easier.
Great. That helped a lot. I have set the LED to 156 bc my blade is a little longer.
Any problems about this?
// ProffieOS7 Config File
const unsigned int maxLedsPerStrip = 156;
#define VOLUME 1000
#define CLASH_THRESHOLD_G 3.0
#define SAVE_PRESET
#define FETT263_QUICK_SELECT_ON_BOOT
#define FETT263_RANDOMIZE_QUOTE_PLAYER
{ "ESB;common", "common/tracks/Wampa.wav",
StylePtr<InOutHelper<SimpleClash<Lockup<Blast<AudioFlicker<DeepSkyBlue,SteelBlue>,White,200,100,400>,Pulsing<Gradient<AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>>,Gradient<AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<DeepSkyBlue,SteelBlue>,AudioFlicker<DeepSkyBlue,SteelBlue>>,3500>,AudioFlicker<White,DeepSkyBlue>>,White,40>,180,500,Black>>()},,
"preset0"
{ "FatherESB;common", "common/tracks/Bespinsc.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},,
"preset1"
{ "Father;common", "common/tracks/bespinpreon.wav",
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Green>,RotateColorsX<Variation,Rgb<0,128,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()},,
"preset2"
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>()
/* Generated with Fett263 Config Helper v3.08 */
You need to add the BladeConfig section from your original config per the instructions at top of the tool, otherwise this is an incomplete config.
In addition, you didn’t enable an Edit Mode menu so it’s still not active and if you want to use Edit Mode you should generate new style code from my library, your style code is very old and does not support most of the Editing features.
This shows an error:
Compilation error: ‘blades’ was not declared in this scope; did you mean ‘bladePin’?
#define VOLUME 1000
#define SAVE_PRESET
#define BLADE_DETECT_PIN blade3Pin
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
"preset0"
StylePtr<Layers<RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
"preset1"
"preset2"
#ifndef BLADES_ABSTRACT_BLADE_H
#define BLADES_ABSTRACT_BLADE_H
#include "blade_base.h"
BladeBase* GetPrimaryBlade();
class AbstractBlade : public BladeBase, public SaberBase {
public:
AbstractBlade() : SaberBase(NOLINK) {}
void Activate() override {
SaberBase::Link(this);
void Deactivate() override {
SaberBase::Unlink(this);
size_t GetEffects(BladeEffect** blade_effects) override {
*blade_effects = effects_;
while (num_effects_ &&
micros() - effects_[num_effects_-1].start_micros > 7000000) {
num_effects_--;
return num_effects_;
void SetStyle(BladeStyle* style) override {
// current_style should be nullptr;
current_style_ = style;
if (current_style_) {
current_style_->activate();
BladeStyle* UnSetStyle() override {
BladeStyle *ret = current_style_;
if (ret) {
ret->deactivate();
num_effects_ = 0;
current_style_ = nullptr;
return ret;
BladeStyle* current_style() const override {
return current_style_;
void SB_Effect2(BladeEffectType type, float location) {
switch (type) {
default: break;
case EFFECT_LOCKUP_BEGIN:
switch (SaberBase::Lockup()) {
case LOCKUP_DRAG:
type = EFFECT_DRAG_BEGIN;
case LOCKUP_NORMAL:
break;
default: return;
break;
case EFFECT_LOCKUP_END:
case LOCKUP_DRAG:
type = EFFECT_DRAG_END;
case LOCKUP_NORMAL:
break;
default: return;
break;
case EFFECT_CLASH_UPDATE:
return;
for (size_t i = NELEM(effects_) - 1; i; i--) {
effects_[i] = effects_[i-1];
effects_[0].type = type;
effects_[0].start_micros = micros();
effects_[0].location = location;
effects_[0].sound_length = SaberBase::sound_length;
effects_[0].wavnum = SaberBase::sound_number;
num_effects_ = std::min(num_effects_ + 1, NELEM(effects_));
bool IsPrimary() override {
return GetPrimaryBlade() == this;
void SB_On2() override {
SB_Effect2(EFFECT_IGNITION, 0);
void SB_Off2(OffType off_type) override {
switch (off_type) {
case OFF_BLAST:
SB_Effect2(EFFECT_BLAST, (200 + random(700)) / 1000.0f);
break;
case OFF_NORMAL:
case OFF_FAST:
SB_Effect2(EFFECT_RETRACTION, 0);
break;
case OFF_IDLE:
case OFF_CANCEL_PREON:
// do nothing
break;
protected:
BladeStyle *current_style_ = nullptr;
private:
size_t num_effects_ = 0;
BladeEffect effects_[5];
#ifdef BLADE_ID_SCAN_MILLIS
bool ScanBladeIdNow();
This one was working with my blade. I made the blade myself and like to get 156 LEDs.
#define VOLUME 100
Did you watch the videos at the top of the tool and read the Instructions in the box below the BladeConfig input?
No to the Videos
and yes to the Info in the box. As i made my own blade out of two stripes of Ws2812b that are using 3 pins, where can i get my blade config or what can i use.
thx
Andreas
You need the BladeConfig from your original config.h file provided by the installer, this will tell the OS how they are wired to the board and what type of blades are used.
The instructions and videos show an example of what it should look like.
I installed the 7.13 from here ![]()
My LED stripe is configured as shown in the standard diagram
Then you need the BladeConfig that matches that wiring. It would have been in your original config file -or- you need to generate from the configurator you used to generate the wiring diagram.
And it worked! Thank you for your support.
It feels like i tipped my toe into the water and now it’s warm. I like that ![]()
thx ![]()
Andreas
Great to hear. Just review the Button Control List to familiarize yourself with the various controls based on your selections.
