Hello, is it possible to have a style with all the survivor colors, so 10, plus another of each color for the crossguard fonts, so you start on blue, you special ability to blue crossguard, then cyan and cyan crossguard etc etc that would mean 20 alt font folders, it only lets me add 10 styles to the multi phase currently, so i don’t see how it would work currently
The max the library handles is 10 phases (0 ~ 9). You could do 2 presets with 10 each. But getting 20 phases in one style would have to be a manual process. I’d recommend testing if you did attempt to manually write 20 phases in. There is a point where the style will become too complex to run properly, 20 seems like that is probably pushing it a bit.
