SOLVED!
SubbladeZZ fixed the problem.
I installed this 42 pixel “bar graph” the other day, and to run it I have it split into three 14 pixel blades, using subblade with strides. Everything mostly works as intended, but if, for example, I have the two outer blades use different colors or effects, they combine each style on each blade. Though it’s washed out with brightness, you can see how in the reflections of color it alternates blue and green. That was supposed to be one side all green and the other all blue with gold in the middle.
This does produce some cool effects, like if I set a running effect at two different speeds on the two outer blades it gives each like a comet tail. But I don’t think this is intentional.
I am using a v3 board running OS7.10.
Since the config is quite large (too large for pastebin), here is just the blade config part and the style shown.
Is this normal, or did I screw up somewhere?
