StyleHelper RGBA_nod
A second config that I’m working on is throwing an RGBA_nod error.
I watched all of Brian’s video (https://youtu.be/GzuPCI8TLmY?si=gol_wcizVsNW0FAE&t=1434 ) , in which he discusses that this is often due to a transparent layer. I followed his instructions and added the “Black,” code right after the “Layers” statement, but it didn’t fix the issue.
Config in Pastebin - HoCStyleTest - Pastebin.com
Error :
In file included from E:\Documents\Sabers\Proffie\ASP2 - Blue\04-2026 - 33 inch Quantum\ProffieOS\styles\fire.h:4,
                 from E:\Documents\Sabers\Proffie\ASP2 - Blue\04-2026 - 33 inch Quantum\ProffieOS\ProffieOS.ino:469:
E:\Documents\Sabers\Proffie\ASP2 - Blue\04-2026 - 33 inch Quantum\ProffieOS\styles\style_ptr.h: In instantiation of 'OverDriveColor StyleHelper<RetType>::getColor(int) [with RetType = RGBA_nod]':
E:\Documents\Sabers\Proffie\ASP2 - Blue\04-2026 - 33 inch Quantum\ProffieOS\styles\style_ptr.h:35:18:   required from here
E:\Documents\Sabers\Proffie\ASP2 - Blue\04-2026 - 33 inch Quantum\ProffieOS\styles\style_ptr.h:35:63: error: could not convert '((StyleHelper<RGBA_nod>*)this)->StyleHelper<RGBA_nod>::getColor2(i)' from 'RGBA_nod' to 'OverDriveColor'
   35 |   OverDriveColor getColor(int i) override { return getColor2(i); }
      |                                                               RGBA_nod
Compilation error: could not convert '((StyleHelper<RGBA_nod>*)this)->StyleHelper<RGBA_nod>::getColor2(i)' from 'RGBA_nod' to 'OverDriveColor'
Another example of the code working fine in the Style Editor, but not through Arduino.
OS 7.15
Your second style is a stack of Layers<> that starts with AudioFlickerL, which is transparent.
Generaly, Layer<> stacks should start with something non-transparent.
Can someone help me by pointing out where that is and what should be put in its place, please?
Does it work if you just remove the “L” from AudioFlickerL ?
No, and it results in significantly more errors.
FWIW, more errors doesn’t necessarily mean worse.
Could you share those errors?
I’m trying to log in to Pastebin, but it looks like cloudflare is acting up.
