I have been reading through the style site and i seem to be missing how to incorporate the accent lights into the blade styles. I have a set of neopixel strips on the sides of my saber that i have set up like quillians and i want to know how to add them to the blade style.
Dave
You can copy the main blade style and paste it for those blades as well.
Additionally, you may want to remove the layers for effects like clash and blast as in theory they wouldn’t show on them.
You can also alternately add IgnitionDelay<> if you want them to ignite a short time after the main blade.
There are fonts that include a “dual ignition” out.wav for just such an effect.
Hope that helps.
You can use Secondary/Quillion blades or Accent styles from the library Then add them to the preset for those blades, assuming you’ve wired or configured them separately.
So if i understand correctly, i setup the main blade style then after that block of code i paste the secondary/quillion after that.
kind of like this?
/* copyright Fett263 UnstableBlades (Primary Blade) OS6 Style
OS6.6 v3.05
Base Style: Unstable Anger
–Effects Included–
Preon Effect: Overload (PreOn Color)
PowerUp Effect: Power Surge (Unstable V1)
Retraction Effect: Dual Mode Wipe In (Up = Fast)
PostOff Effect: Emitter Cool Off (Emitter Size)
Melt Effect: Intensity Melt
Stab Effect: Sparking Stab
Clash Effect: Real Clash V1
Emitter Effect: Unstable Flare
Emitter Off Effect: Base Color Pulse (One-Time Preset Indicator)
*/(blade info omitted for length)
/* copyright Fett263 UnstableBlades (Quillion / Secondary Blade) OS6 Style
OS6.6 v3.05
–Effects Included–
Preon Effect: Faulty Ignition (PreOn Color)
PowerUp Effect: Power Flash
CoolDown Effect: Unstable Cool Down Reverse
Lockup Effect: Intensity Lockup Up V1
Blast Effect: Blast Wave Up (Sound Based)
Clash Effect: Real Clash V1 Up
*/(blade info removed for length.
Yes, assuming you have 2 blades set up.
I have the accent setup as a 2nd blade so it mimics the main blade colors and actions.
Cant wait to test more of the os6 blades. You did some nice blades.
Thank you
