Struggling to set up blade ID
Trying to set up blade ID but I don’t know what I’m doing. I have a thin neck saber with crystal chamber, its not wired for blade detect, so from reading the documentation it seems that limits the capabilities of blade ID. but all I want to do Is detect when the core is in or out and it seems that is possible from my understanding? I’m not sure how its wired so that might be an issue.
.after trying myself I just cant seem to get it to work, I read the documentation and adhered to it as best I could but it just hits me with an error when I try verify the code. I think I am failing to define something.
Here is the config;
// ProffieOS7 Config File
#define NUM_BLADES 5
#define VOLUME 1750
#define CLASH_THRESHOLD_G 3
#define KILL_OLD_PLAYERS
#define MOTION_TIMEOUT 60 * 2 * 1000
#define SHARED_POWER_PINS
#define FETT263_MAX_CLASH 14
#define BLADE_ID_TIMES 15
// #define FETT263_DISABLE_QUOTE_PLAYER
// #define FETT263_RANDOMIZE_QUOTE_PLAYER
#define FETT263_TRACK_PLAYER_NO_PROMPTS
#define FETT263_SWING_ON_SPEED 600
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
#define FETT263_STAB_ON
#define FETT263_STAB_ON_NO_BM
#define FETT263_FORCE_PUSH_LENGTH 8
#define FETT263_CIRCULAR_VOLUME_MENU
#define FETT263_CIRCULAR_DIM_MENU
// Luke Green ROTJ Final Dule
Preset blade_1 [] = {
// Track
{ "ROTJFD;common",  "ROTJFD/tracks/throne_duel.wav",
OS7.14 v3.24p
Style Option
Base Color: BaseColorArg (0)
// Main Blade
OS7.14 v3.24p
Multi Phase (Original - Color Change) Transition: Smooth Fade, Time: 1000
Default: Hyper Responsive Rotoscope (Original Trilogy) [BaseColorArg]
1: Kylo Ren Unstable (Film Based) [AltColor2Arg]
OS7.14 v3.24p
Effect Reaction: AudioFlicker, IgnitionColorArg, Type: Responsive Center, Direction: Normal, Duration: 500, Consecutive Effects to Max: 6
Effect Reactions: Clash, Blast, Lockup, Lightning BlockIgnition Effect: Standard Ignition [Color: IgnitionColorArg]
Lockup Effect:
0: mainLockMulti0Shape - Begin: Real Clash - Style: Intensity AudioFlicker - End: Localized Absorb
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
0: mainMeltMulti0Shape - Begin: Wipe In - Style: Original Melt - End: Wipe Out
[Color: StabColorArg]
Stab Effect: AudioFlicker Stab [Color: ClashColorArg]
Blast Effect: Responsive Blast Fade (Random) [Color: BlastColorArg]
Clash Effect: Real Clash V3 [Color: ClashColorArg]
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,AlphaL<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<20000>,Int<32000>>,Int<8000>>>,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<20000>,Int<32000>>,Int<8000>>,Int<45000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,17608>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<300>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<20000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<20000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<16000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Int<13000>>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,22139>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<HumpFlicker<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,17608>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<415>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
// Focus crystal
/* copyright Fett263 (Crystal Chamber) OS7 Style
OS7.14 v3.24p
On Behavior: AudioFlicker (Single Color) [Color: BaseColorArg]
Off Behavior: Off [Color: OffColorArg]
Effect Reaction: Static Color, IgnitionColorArg, Type: Emitter, Direction: Normal, Duration: 500, Consecutive Effects to Max: 6
Effect Reactions: Clash, Blast, Lockup, Lightning BlockIgnition Effect: Instant [Color: IgnitionColorArg]
PowerUp Effect: Power Flash [Color: IgnitionColorArg]
CoolDown Effect: Power Flash [Color: RetractionColorArg]
Lockup Effect: NoneLightning Block Effect:
0: crystalLBMulti0Shape - Begin: Responsive Impact - Style: Strobing AudioFlicker - End: Full Blade Absorb
[Color: LBColorArg]
Drag Effect: NoneMelt Effect: NoneClash Effect: Real Clash V1 Up [Color: ClashColorArg]
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,AlphaL<AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<Int<40000>,Int<-10000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_RETRACTION>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>,50,1>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,InOutTrL<TrInstant,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
// Kyber crystal
OS7.14 v3.24p
Off Behavior: Solid Color [Color: OffColorArg]
[Color: LBColorArg]
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,AlphaL<AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<Int<40000>,Int<-10000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_RETRACTION>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>,50,1>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,InOutTrL<TrInstant,TrWipeInX<BendTimePowX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Layers<Rgb<0,5,0>,AlphaL<Green,NoisySoundLevel>>>>>(),
// Blinkers
StylePtr<Layers<Black,InOutTrL<TrInstant,TrInstant,TransitionLoop<Black,TrConcat<TrDelay<3000>,Red,TrBoing<2000,5>>>>>>(),
StylePtr<Layers<Green,InOutTrL<TrInstant,TrInstant,TransitionLoop<Green,TrConcat<TrBoing<3000,9>,Black,TrDelay<2000>>>>>>(),
"preset0"
// Track 2
{ "ROTJSB;common",  "ROTJSB/tracks/Sail_Barge_Assault.wav",
// Main Blade
OS7.14 v3.24p
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
// Focus crystal
OS7.14 v3.24p
[Color: LBColorArg]
// Kyber crystal
OS7.14 v3.24p
[Color: LBColorArg]
// Blinkers
"preset1"
// Track 3
{ "ROTJSB-Blue;common",  "ROTJSB-Blue/tracks/Sail_Barge_Assault.wav",
// Main Blade
OS7.14 v3.24p
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,220,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,220,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,220,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,220,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,220,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,220,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,220,255>>>,AlphaL<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<20000>,Int<32000>>,Int<8000>>>,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<20000>,Int<32000>>,Int<8000>>,Int<45000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,17608>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<300>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<20000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<20000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<16000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Int<13000>>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,22139>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<HumpFlicker<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,17608>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<415>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
// Focus crystal
OS7.14 v3.24p
[Color: LBColorArg]
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,240,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,240,255>>>>,AlphaL<AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<Int<40000>,Int<-10000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_RETRACTION>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>,50,1>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,InOutTrL<TrInstant,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
// Kyber crystal
OS7.14 v3.24p
[Color: LBColorArg]
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,240,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,240,255>>>>,AlphaL<AlphaL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<Int<40000>,Int<-10000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<RetractionTime<0>>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_RETRACTION>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,LockupTrL<Stripes<3000,-2000,RandomBlink<30000,Strobe<Rgb<125,125,225>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>,50,1>,Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>>>,TrWipe<200>,TrWipe<200>,SaberBase::LOCKUP_LIGHTNING_BLOCK,Int<1>>,InOutTrL<TrInstant,TrWipeInX<BendTimePowX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Layers<Rgb<0,4,5>,AlphaL<Cyan,NoisySoundLevel>>>>>(),
// Blinkers
"preset2"
// Track 4
{ "MandoS2Luke;common",  "MandoS2Luke/tracks/Friend.wav",
// Main Blade
OS7.14 v3.24p
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,255,0>>>,AlphaL<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<20000>,Int<32000>>,Int<8000>>>,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<20000>,Int<32000>>,Int<8000>>,Int<45000>>>,HoldPeakF<Mult<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<30000>>,ThresholdPulseF<InvertF<HoldPeakF<Sum<EffectPulseF<EFFECT_CLASH>,EffectPulseF<EFFECT_BLAST>,LockupPulseF<SaberBase::LOCKUP_NORMAL>,LockupPulseF<SaberBase::LOCKUP_LIGHTNING_BLOCK>>,Int<500>,Int<8172>>>,Int<30000>>,Int<32768>,Int<5461>>>,Int<500>,Int<10000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,17608>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<Scale<BladeAngle<>,Int<28000>,Int<8000>>,Scale<EffectPosition<EFFECT_BLAST>,Int<9000>,Int<13000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<255,0,0>>>>,TrFade<300>>,EFFECT_BLAST>,AlphaL<TransitionEffectL<TrSelect<Scale<ClashImpactF<>,Int<0>,Int<4>>,TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<ClashImpactF<>,Int<8000>,Int<12000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<600>>>>,TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,Stripes<1500,-3000,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>>>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,TrConcat<TrInstant,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<Scale<ClashImpactF<>,Int<300>,Int<500>>>>>,EFFECT_CLASH>,Scale<ClashImpactF<>,Int<24000>,Int<32768>>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<20000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<20000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<12000>,Int<16000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,20931>,Int<-10000>>>,Int<13000>>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<15,0,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,22139>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<HumpFlicker<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,17608>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<200>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<550>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
// Focus crystal
OS7.14 v3.24p
[Color: LBColorArg]
// Kyber crystal
OS7.14 v3.24p
[Color: LBColorArg]
// Blinkers
"preset3"
Preset no_blade[] = {
{ "font", "tracks/track",
StylePtr<Red>(),
StylePtr<Red>(),
StylePtr<Red>(),
"preset4"},
    WS281XBladePtr<1, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    WS281XBladePtr<1, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin7, -1, -1, -1>(),
	SimpleBladePtr<CH2LED, NoLED, NoLED, NoLED, bladePowerPin8, -1, -1, -1>()
  , CONFIGARRAY(blade_1), "blade_1_Save" }  ,
{ 200000, WS281XBladePtr<1, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
  , CONFIGARRAY(no_blade), "no_blade_Save" }  ,
Button PowerButton(BUTTON_POWER, auxPin, "pow");
Button AuxButton(BUTTON_AUX, powerButtonPin, "aux");
What is the error you’re getting?
So how would you detect it?
What circuit will open or close when you insert the core is inserted?
i actually fixed the error, and got the thing to upload. but i cant get the resistance values to work. sometimes it uses preset one and sometimes preset two.
this seems to activate present two
{ 10, WS281XBladePtr<1, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
part of the issue is I’m not even sure what I’m trying to do will work. my assumption is there is some amount of resistance in the emitter section even without the blade and i can use that difference. but idk, you tell me.
That’s not how it works unfortunately.
While every wire has some resistance, you have to have a complete circuit to measure it.
Blade ID can measure resistance because there is a resistor between GND and Data.
If you measure the resistance between GND and Data with only the emitter section, what you’ll find is that the resistance is very high, because there is an air gap between them.
RIP oh well it was worth a try! thanks for the help.
is this the value you get for the BLADE ID when running scanid in serial monitor with the chassis inserted?
What does it say when it’s removed?
