Hello,
I’m receiving the following error, hoping someones can help. Thanks!
Arduino: 1.8.19 (Mac OS X), Board: "Proffieboard V2, Serial + Mass Storage, SDCARD (SPI), 80 MHz, Smallest Code"
ProffieOS:1:1: error: stray '\303' in program
1 | Í›/*
ProffieOS:1:2: error: stray '\215' in program
1 | Í›/*
ProffieOS:1:3: error: stray '\342' in program
1 | Í›/*
ProffieOS:1:4: error: stray '\200' in program
1 | Í›/*
ProffieOS:1:5: error: stray '\272' in program
1 | Í›/*
Read the weird-unicode-character-errors section.
However, based on your posted error report, you can see that it’s line 1, character 1 of your ProffieOS.ino file.
The first characters of the file are /* which opens the comment block that follows.
You inadvertently bumped the keyboard or something while that file had the cursor at the top of the file, and a weird character got added.
Even if it weren’t a weird character, it doesn’t belong before the opening /*
So to summarize, just delete that thing and you might be good to go.
That doesn’t detract from the original answer, including the suggestion to edit your config file with a code friendly text editor like Sublime Text or Visual Code so as to prevent fancy invalid characters from being introduced to your code.
That makes sense. Appreciate the tip on how to read the error code. Deleting it fixed it. Thanks again!
