Hi!
Some random person recently dropped my proffie 2.2 lightsaber, which broke the board (I’ve deduced, since it will no longer communicate with my computer, and all the other wires are ok) Which is ok because I was looking for a reason to upgrade and swap out the board to a 3.9 anyway! However, I want to still figure out how to fix the 2.2, (which I’d appreciate advice for how to go about that), and want to put it in a thermal detonator as detailed by your tutorial! The first link however I dont think works anymore, for the “Thermal Detonator Kit”, it just takes me to saber armory home page. Is that supposed to be the detonator “shell”? I apologize for my ignorance if this is a simple answer and a dumb question. And then everything else on the page should be easy to follow? Any tips?
You guys are the best as always and I’m excited to get started! <3
Since I decided to be an A-hole and not research the slightest bit before posting this, I’ve since learned that the link not working is because I am too late
. Are there any alternatives for the kit so that I can still use my extra proffieboard? (if i fix it)
or if not, are there any other cool ideas? I’m assuming maybe theres a Han Solo gun I can do somewhere, but the TD would be much prefered.
The Saber Armory is actually doing another run of TDs soon!
Boy oh boy, how convenient!
Any idea on when yet?
They are selling fully installed TDs this month, so I would think they would sell the empty kits soon.
If I were to build another TD, I would definitely use a V3 proffieboard. The extra memory would be overkill, but the builtin charger would save some space, which is always helpful. The charger isn’t particularly fast, but the battery probably won’t be particularly big, so it kind of evens out…
The disconnect circuit I used in my TD would require the TD to be on while charging, but once it’s exploded, it doesn’t make any sound, so that should be fine I think.
So are you saying I should use the 2.2 with your TD guide if I can fix the board or should I buy another 3.9? I just feel like I’m wasting the 2.2 that I have just having it sit around, unless you have a better idea for it.
Also any ideas on how to go about fixing a dropped proffieboard? I have no idea yet where to start to try to find the problem
Well, no not really.
If you’re building exactly the same thing that I did, then a V2 board is fine, since there is already room for a charge port in there.
However, if you are changing or re-designing anything, I would go for a V3 board.
As for how to fix a board, well, the first thing is to figure out what works and what doesn’t:
- inspect the board under magnification, do you see any shorts? missing components? broken traces? cracks? If so, those are most likely the problem.
- Measure the resistance between BATT+ and BATT-, if it’s less than 2 ohm, there is a short somewhere, and you should not plug the board in. (It will get hot and possibly catch on fire.)
- Plug the board into a battery and/or usb. Measure the voltage between GND and the 3.3v pad. If you don’t have ~3.3 volts, the 3.3v regulartor, or the diods that feed it are broken somehow. (or there is a short)
- If the 3.3v works, the CPU should work, more or less… That means that you should at least be able to plug it in and program the board. If not, the CPU is broken.
- If the CPU works, it’s time to check each peripherial: FETs, SD, Booster, Audio, Motion and data pads. If you actually get here, let me know and I can provide additional instructions.
Thanks for the tips on how to fix the board! I will look more into it when I get home.
Do you predict that the new Project Boushh TDs (KR Sabers new TDs that come out this month) will let me be able to do the same process that you did or is there no way to know? I’m just confused on if their new TDs are completely revamped or just a restock or what.
I am not skilled enough to redesign anything lol, I just want to copy a process as an excuse to use this board.
This is what is coming out:
You da man!
It’s likely quite different than proffzzorns.
That said, it’s a hollow ball. What you do inside is up to you completely.
It’s a niche project prop, but people have made internal chassis for the various versions out there to hold all your parts just right. Typically, you’d want to do that, so it depends on what you end up getting.
If you do wait for the KR Version, once the kits are available as broken out parts, you can get the shell and a chassis and use your own electronics.
Get a new V3.9 board. it’s worth the $30 or whatever to not bother fixing the 2.2.
It did its job. Let it rest. Trust me, I know from fixing a bunch.
It is a good ,fun learning experience, so it’s up to you of course.
Maybe you broke the USB port off just enough that data doesn’t work anymore. In that case you could probably just reflow the solder connections on the port and it might fix it.
It might not be that simple. You never know.
ooooof they just announced the pre-orders and the prices for their new TD’s… Its a little rough. Because these are new, do you think I’d be able to get a 3d file for the chassis somewhere? Or do you forsee someone making one for the new ones/it being any different?
Basically, should I buy the DIY kit for $450 or the empty shell for $330 and do it myself?
You’ll need to ask Khal.
He should at least be able to tell you what the rough differences are, if any.
Do I shoot him an email or does he monitor the crucible?
I’m assuming he’s the “K” in KR Sabers?
@krsabers Hi Khal, as refenced above, I’m wondering if its a bad idea for me to cheap out and just get the empty kit for the new TD’s and trying to DIY it myself, especially since I already have an extra proffieboard. Are the chassis kits previously created by people not compatible with this new version/would I have to design a new one? Thanks a lot!
Additionally, if I were to decide to bite off more than I can probably chew and buy the empty one and design my own everything, is your new config file/sounds available to download/purchase seperately? This might just be matter of me buying the ECO DIY kit, but that’s a little out of my range, but I don’t want to miss out on these!
And additionally one more time, since I just can’t seem to do all my research before hand…
Would something like this be able to work with your instructions @profezzorn ? Minus maybe some tweaks with the chassis?:
ONEREPICA
You should be able to get your questions answered on the info page Khal sent out today. Thermal Detonator Run 2026 – KR Sabers
Yeah, I saw already saw that, I still have the same questions…
Fair enough. You might email him.
