Had a person reach out to me about a problem they are having with their two proffie sabers. I’m not sure what the problem would be. Basically what is happening is they get a high pitched ringing when using the proffie saber. The other saber that had this ringing and blew the speaker. Any help would be appreciated.
I’ve heard two different things that could cause such a problem, either SD card or the config itself. My assumption is that the saber config maxed out the space on the board and the processor is having trouble keeping up.
I believe this saber was originally installed with an older OS probably 5.7. The Saber has around 34 fonts at 100% storage space.
config attached below:
tedflex.h (56.2 KB)
