Hi Fett, just like to say the OS7 library is incredible, I don’t know where you find the time to do it.
I’m having trouble using the special ability controls, for example I want to trigger rain mode using USER1 hold power and twist right, sometimes I can pull it off other times the saber powers off, any advice? Thanks
If sometimes it works, it’s likely just you needing to “practice” the move.
Don’t try to press and hold the button and twist at the same time.
Press button and hold, then twist while holding.
Don’t wait, just back-to-back.
And the “twist” is really a “rotate right” or left 1/4 turn. Like turning a key in a door.
Hope that helps.
The rain will start, then let go of the button ![]()
Got it, thanks guys🙂
