Hi guys,
Witch of these would be good for a Proffie test bed:
Amazon.de : uxcell 100 Pcs Spring Load Spear Tip Test Probes Pins 1.3mm Diameter
Most seem to deliver to Malta for a reasonable price but I can’t tell the difference between most. What do I need to look for ?
Thanks as always.
MTFBWY
orntar
April 10, 2025, 3:17am
2
I bought (and use) the uxcell pins and they work perfectly.
The first ones:
Mit spear tip design, einfach zu montieren, Sehr praktisch um bei einer weit verbreitet in der Datenkommunikation Ausrüstung, Behälter, wire wrap board, PC usw.).
25,63€
They are basically the same that I use.
The hole is just under 1mm, so you want the head to be pointy and larger than one mm.
The barrel is slightly larger than 1mm, so make sure your PCB can accommodate that.
These?
Features spear tip design, easy to mount, very handy for testing. Widely used in data communication equipment, receptacles, PC board, wire wrap etc.
$18.39
I think I’ll start my spring projects with finally making a test station
orntar
April 10, 2025, 12:08pm
5
Yep, those. I made a bed for 2.2 and 3.9. So I have some left over.
