the website keeps saying error
I know sorry. Iām revamping a lot and will have it up ASAP. For now, thereās a reset on the current version hourly
Q: Is there an offline version I can download and use?
Iāve been refreshing the page every hour for 12 hours, it still hasnāt come back up. :-/
I was in the middle of running the proffie optimizer on 48 fonts, and then the converter on 77 fonts to convert from Xenopixel to Proffie.
I got as far as 9 fonts this morning before it started just loading the application error screen.
Iāve been refactoring the code for 2 weeks straight. Finally have version 4 mostly ready. Hopefully it plays nicer on Heroku.
The analytics are a mess n the current version with a ton of timeouts and java heap out of memory errors.
It resets hourly, so it really shouldānt be an issue. Although, if users are hammering it, that could be it.
Almost there. hopefully pushing update tonight.
Ah ok.
I noticed it was up, got another 3 āoptimized for proffieā before it went down again. Maybe iām going too fast?
Itād still be good to have an offline downloadable script or app, you know, for 30+ years from now when I want to go tinker with ancient sabersā¦
I see 3.1 just appeared.
the download button is partially cutoff and thereās no scroll down ability yet.
Also, I see no upload progress bar, i am clicking convert within a second of clicking upload and itās still working, but idk ppl with slow internet will handle that.
Ok I updated the CSS. Better now?
itās all on GitHub. Link in top post.
youād need to have a bunch of stuff installed. Spring boot, Maven etcā¦
Files upload when you click Convert.
sweet, yeah itās working better ![]()
Only one minor visual bug: When going through doing multiple fonts, the download button stays as āRe-download converted filesā and doesnāt reset to āDownload converted filesā when you click upload the second+ time. The download button should probably go away when you click Convert, and re-appear when it finishes.
This thing canāt handle multiple font folders at once, right? i.e. upload entire SD card, click convert, it does each root directory sub folder?
the script version did multiple levels.
canāt guarantee it handles all things as fine tuned as they are in the current version
but youāre welocome to play
If I want to use this to optimize my proffie fonts for FAT32, can it handle alt folders? Based a quick test the answer seems to be no, but I wanted to make sure I didnāt miss something.
Grr⦠no.
Let me get to that.
No biggie. I can just run each alt folder through the converter on its own as a workaround.
4.0 is almost done. Itāll have a standalone audio converter, incorporate alt fonts, and hopefully handle a folder of folders so you can do multiple fonts in one shot.
Iām going to guess it doesnāt like that many fonts at once, but I made it support multiples.
I also included the source path in the logs for extras and tracks as per your request.
I finally get Audacity and MacOS14.3 working and now this update to 4.0?
Thanks @NoSloppy!! Itās PartyTime!!
Not sure if Iām doing something wrong, trying to optimize a proffie font for FAT32, but its just loading endlessly. How long does this usually take? I thought it was a sub-folder issue so i just have all the .wav files in the soundfont folder but still no luck.
