Sound stutters at certain point in a font
Hi there i have a kylo saber with the 3 blades and in one font i just added the sound will stutter at a certain point during the hum or playing its music track, are the files corrupt? Bad sd card? Need some advice on what to do, thanks
I’d start by reformatting the card and reloading the fonts. Be sure to back everything up of course.
If that doesn’t fix, see if you can narrow down to a file by viewing Serial Monitor for which file is playing (or if there’s any odd messages the correspond to the sound issue).
Hi Fett,
Formating and reloading the files did the trick, thanks for your help👍
Good to hear. Be sure you’re always ejecting your SD after adding or removing files on a computer. Failing to eject can cause corruption or issues.
