Hello, community friends. I created a sound font for my Sith Inquisitor saber. I took parts from the SWTOR game and some from other sources. My problem is that some sounds ended up with very low volume, while others are much louder. Is there a way for someone with little experience to fix this? Or is there a program I can use to level the volume of the sounds?
You can normalize your audio clips with Audacity, which is the freeware many of us use.
Here’s how I do it. Start at about 3:40.
https://youtu.be/S98FfLHZWZs?si=f7IRkYOq_YxG2VQa
thank you so much , that helps a lot
Audacity isn’t just freeware, it’s open-source.
The difference may be academic to most people, but I wanted to point it out since there is a big difference in my opinion.
I am learning how to use it , thank you
FYI you can do Effect>Normalize and set it to 0db and it’ll do what you did in Amplify with no “risk” of clipping as it only does zero and lower.
thank you so much , that seems to be better now all the sounds are leveled ! ![]()
Thanks, BC!
