Hey guys…
I have another issue I’m hoping y’all can help me with. I have two sabers I am working on and am having the same issue with both. Blade one has 16 sound fonts/blade styles, when I try to switch from style #1 to #2, I get nothing, it refuses to cycle any further through the list. No beeps, no error message, nothing. Same with the second blade, it has 13 styles, but once it reaches style #12, it has the same problem as the first blade, it refuses to cycle to style #13, no beeps, no error messages. I’ve compared the scripts of both sabers to each other and to scripts from other sabers that I know I had no issues with and can’t seem to pin-point what the issue is. Anyone have any thoughts??
Thanks in advance =]
This sounds like sd card problems.
If you format an empty sd card and put it in instead, does the freezing go away?
It will give you many error messages about missing font directories of course, but if the freezing go away, then most likely something on the sd card is causing a problem, right?
Hey Profezzorn…
I followed your instructions and it looks like that’s it. I swapped out the SD card for a formatted empty one and it cycled with no issues, but with the font error, like you said. Both cards actually came with the Proffies. I always seem to have a problems with the cards that come with the boards. On a side note, you were right-on with my last issue, for some reason I was using a older Proffie OS. Once I used the updated to the newest version, no errors. Thank you again, you’re the best =D
I’m back. I installed all the fonts onto a new, formatted SD card and I am having the same issue at the same spot (I’ve only tested one board). Also, I noticed that when I press the aux button to select the fonts, a lot of the time I get “beeps”. It gets annoying, sometimes I have to restart the board.
This didn’t happen when I used the SD card when it was clean. Any thoughts?
Well, the firs thought is: Did you you do the “eject safely” and wait for the disk to finish uploading before disconnecting the SD card from the computer?
Second thought: Does the serial monitor say anything interesting when you switch fonts?
I actually get a “try again” message when I try to eject the disk without closing any folders related to the disk or files on the disk. I reloaded all the fonts, closed all the folders and when I ejected, there were no “try again” messages. That worked, I was able to cycle through the fonts several times.
I appreciate your help, I feel kind of stupid when my issues turn out to be something so simple, but at least I’ll know what to do and not to do in the future. Thank you again for your help!
