SOLVED now solved
Found a setting for enable a way to filter posts by their “solved” status.
That might help with finding useful posts.
I’m looking all over . Where are the tags, including the “Solved”?
“solved” is a box that shows up in some categories.
For non-moderatores they only show up on threads that you yourself have started, and it’s you select an answer that solved your question. I think maybe trust-level 3 users can also select them. If I remember correctly, I have only enabled the “solved” button on the proffieboard and proffieos categories so far.
The tags can be applied when you create a new topic or by clicking the “edit” button next to the topic. Again, I think admin, moderators, trust level 3 users and the author of the thread can do this.
