Soldering in the parallel with main blade
is it possible to solder a 3.5mm Width WS2812 2020 Mini Flexible Accent LED Strip - 10 LED in the same contacts of the main blade ?
Yes I’ve done it. You can wire anything parallel to the blade. Just be careful with those mini 10 led strips. If they’re the black ones they are very fragile. One kink and they’re done.
Yes, as long as the strip uses the same byte order as the main blade.
You can’t have one be RGB and the other be WGBR, beucase then you can never make them show the same color.
Do you need
#define SHARED_POWER_PINS
I’m thinking of two cases, one which is shared power and data for both blades, and one where power is shared but data is on separate pads.
Do you need this define for both?
This is when you want the define.
