so when i verify the config i get no errors but when i try to upload the board becomes unrecognizable on my pc and i have to boot and reset the board itself i heard this happens if the code is bad but idk whats wrong with it
in case this is important “The Light” has an alt sound font folder since i wanted that one to switch from light to dark side
so everywhere i try to upload just this config the driver messes up and i have to do these steps to get my board to work again ProffieOS Documentation: How to recover from a bad programming
but when i go back to my normal config on os6 everything works fine and my board starts working normally again
Still need clarity.
The config file from the pastebin link above is being loaded on OS7 beta?
Does it work on OS6?
What’s your “normal config on OS6” ?
You can’t use “FETT263_” defines with sabertrio’s prop. You probably want to reach out them or change to my prop and the main OS. Sabertrio has some differences and issues with ths OS they were originally uploading as well as their prop that made it incompatible with the main OS (and for us to really be able to help).
Info on my prop is here, just make sure you use the main OS.
Otherwise, you’ll want to reach out to SaberTrio for assistance.
okay work has been killing me but i did get the config to work after removing the keep save files now i just gotta figure out how to get the duel phase style to do alt sound fonts and i’ll be set
