Secondary "Blade" Styles
Hello there,
I just finished up a Graflex build and I’m having a bit of a problem with programming my blade styles for Proffie.
I have the main blade fine, but I’m having trouble programming my bubble strip LEDs (there’s 7 pixels if thats important). I can’t figure out how to make them show battery level at boot and have a volume meter while adjusting the volume. I tried dissecting this but to no avail: ProffieOS/proffieboard_v2_ob4.h at 9b8aab86a2de5b56c2626e810401a5010f73da9b · profezzorn/ProffieOS · GitHub
Here’s the style for my main blade:
   { "ESB_Graflex_V1", "ESB_Graflex_V1\tracks\LvsV.wav",
OS6.7 v4.0181
Base Color: Rgb<0,135,255> (0)
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
Any help would be great. Thanks in advance!
I’m not sure if we have a way to show a volume meter while changing the volume.
Maybe we need to add some functions and EFFECTS_ for that…
Here is a style that shows battery on boot:
using BatteryLevelStyle = InOutHelperX<Gradient<Red,Orange,Yellow,Green,Green,Green,Green>, BatteryLevel>;
   // Battery level on boot
    StylePtr<Layers<
      Black,
      TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,  BatteryLevelStyle ,TrFade<1000>>, EFFECT_BOOT>
And one that shows a VU meter of played sound:
 using VUGradient = Gradient<Red,Orange,Yellow,Green>;
 using VUMeterStyle1 = InOutHelperX<VUGradient, SmoothSoundLevel>;
  StylePtr<VUMeterStyle1>(),
Both of these examples are from my K4 config, which also has bubble strip LEDs:
I’m now getting this error message:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Proffieboard V2, Serial + Mass Storage, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from D:\jacob\Documents\Lightsabers\Builds\Graflex (ANH) 2022\ProffieOS-v6.7\ProffieOS\ProffieOS.ino:55:
D:\jacob\Documents\Lightsabers\Builds\Graflex (ANH) 2022\ProffieOS-v6.7\ProffieOS\config\mysaber_config.h:14:27: error: 'InOutHelperX' does not name a type
   14 | using BatteryLevelStyle = InOutHelperX<Gradient<Red,Orange,Yellow,Green,Green,Green,Green>, BatteryLevel>;
Try without the using:
StylePtr<Layers<
  Black,
  TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,InOutHelperX<Gradient<Red,Orange,Yellow,Green,Green,Green,Green>,BatteryLevel>,TrFade<1000>>,EFFECT_BOOT>>>()
Love this idea. Seems simple enough
Agreed, seems like an easy thing to add to 7.x :slight_smile:
Alrighty. So now I don’t get the error message, but I don’t get the effect at all.
Here’s my config:
#define NUM_BLADES 2
#define NUM_BUTTONS 3
#define VOLUME 300
#define CLASH_THRESHOLD_G 3.5
#ifdef CONFIG_PRESETS/
OS6.7 v4.0181
StylePtr<Layers<
  Black,
    WS281XBladePtr<7, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
  , CONFIGARRAY(presets) },
Button Aux2Button(BUTTON_AUX2, aux2Pin, "aux2");
Is the battery connected?
It won’t actually show if you’re just on USB, as the battery will register at 0% in that case.
*I’ll third this with this add-on, I would love to see the bubble strip or even side blades illuminate up as a battery meter. Have the pixels go from red to green and as the voltage drops turn to yellow as the last led goes blank, with yellow into red showing until you’re pretty much at (in this case) just 2 red pixels left and that’s when the low battery alert plays.
All you have to do is stick a battery meter style on those blades.
There are multiple Battery Level style options in my library for “Custom” ON and/or OFF behavior under Accent or Crystal styles in Enhancements screen or you can include in a Build a Sequence.
The battery is connected and is turned on.
Did you EVER see something on the bubble strip?
Are you sure it’s wired correctly to data4 and LED6?
I have. When I first turned on the saber. But thank you so much for mentioning that; I never checked the data pin in the config. It’s data2, not 4. It works now. Thank you! I feel dumb lol. However, is this how it’s supposed to look? IMG-2066 - Copy.MOV - Google Drive
Something like this? (shown on main blade for example)
Something like that. But with colors and more ‘smooth’ when using the gesture for volume.
First of all, I love your library. Quick question though: what are the ‘sequences’?
Nope. Something weird with that data. Supposed to look like this (press boot and wait 1.5 seconds.)
The Style Editor uses auto-animate to simulate a draining battery over time, so you may want to try it a couple of times to see it all.
https://tinyurl.com/2xp2efmo
It can be whatever colors you want, that’s up to the bladestlye you use with it. The style I made has 10 steps, one for each volume level min-max.
As far as I know, volume is stepped levels, not continuous, so you wouldn’t see it gradually moving up and down. Fett263’s prop rotary volume may be different, but I don’t think so.
Huh. What could cause that?
