Season 7 Clone Wars Ahsoka saber build. Which blade style is most accurate?
Hi, I’m new to the community. I just purchased a pair of Clone Wars Ahosoka Tano lightsabers from The Pach Store running the Proffie v2.2 soundboard. I was wondering if anyone can assist me with acquiring the most accurate blade style that would fit her sabers seen in Season 7 of the Clone Wars during the siege of Mandalore?
The animated series, by and large, have no animation or movement in the blade itself. They are just a Static color. You can just select “Static” from the Simple blades style options in my library:
https://www.fett263.com/fett263-proffieOS7-style-library.html#Simple
For colors, it will depend on your blade (pixels, diffusion, blade clear, sanded, etc). The lighting in your environment will also affect how you “see” the color, so I typically tell users to adjust the color to their taste. You can start with Blue and then adjust to your liking.
Thank you so much for your assistance Fett! It definitely helped me with creating my animated saber style choices for my fonts!
You’re welcome, glad to hear.
