Mostly. Everything will work the same as long as you don’t try to look inside the savefiles. If you want to read or modify the savefiles from outside of ProffieOS, some additional steps will be needed.
Modifying the safefiles directly is definitely peeking under the hood though…
Thanks Prof.
Yeh I’ve never been one to mess with save files (other than simply deleting them) as I’ve always felt its too easy to cause conflicts with them. I think it sometimes gets to a point where learning how to tweak them safely is no less complicated than learning how to upload a new config.
Thanks for clarifying though.
Well if that’s basically the same then, are we dealing with the potential influence of compiler optimizations depending on whether VERBOSE_SD_ERRORS is defined or not?
It doesn’t seem like a delay would help since if there are no errors, the talkie and STDOUT don’t even occur (and taking up some time), but just to test, should we try adding a delay something like
if (!DOSFS.begin()) {
delay(1000);
return false;
This is why I think it might be a buffer overflow somewhere.
A buffer overflow is essentially a “holistic” error, because a problem in one part of the code can cause a symptom in another part of the code, and the link between the two can be determined by code order, optimizations and any combination of the two.
