I’m a newbie to lightsaber building, and looking for some help troubleshooting my first saber.
I am using:
Proffie V2.2 with ProffieOS version 6.7
3-channel Cree XP-E2 LED star
CK TS01CQE kill switch
3.6V battery (I have tried two of these, fully charged)
I don’t remember what type of speaker I have, but it seems to be working fine.
Whenever I swing the saber too aggressively (which isn’t much) or lightly tap the saber, it turns off (both the sound and LEDs) and does not turn back on when the button is pressed. Specifically, this happens when I tap the board itself, but sometimes it seems more random. Regardless of if the saber is moved/tapped again, it functions normally once I toggle the kill switch, at least until it is jostled.
I tried using the standard config file from the configurator instead of my own, but am still experiencing the same problem. I really hope this is not a soldering
issue, but again, I’m a beginner, so its not unlikely. If someone can help me figure out what’s going on here, it would be much appreciated.
