rxPin as Blade detect (error)
Hello there,
Made a little wiring mistake on a prototype that I cannot fix (without dismounting everything, which I’d like to avoid).
The result is that I can only use rxPin as blade detect pin #define BLADE_DETECT_PIN 16
Which result is error in compiling since that pin isn’t meant for that.
My question is, can I just for this build fix this or I just give up on the blade detect?
Arduino: 1.8.3 (Windows 10), Board: "Proffieboard V3, Serial + Mass Storage, SDCARD (SDIO High Speed), 80 MHz, half, Smallest Code"
In file included from D:\08-GOTH-3Designs\SB-ProffieBoard\ProffieOS 8\ProffieOS\ProffieOS.ino:42:
sketch\common/resources.h: In instantiation of 'struct PO_ResourceTracking::UseResource<PO_Resources::InputPin<16>, PO_SubSystems::PO_SERIAL>':
sketch\common/resources.h:49:17:   required from 'struct PO_ResourceTracking::UsePin2<16, PO_SubSystems::PO_SERIAL, true>'
   49 |   static_assert(sizeof(UseResource<InputPin<pin>, USER>));
sketch\common/resources.h:63:17:   required from 'struct PO_ResourceTracking::UsePin<16, PO_SubSystems::PO_SERIAL, true>'
   63 |   static_assert(sizeof(UsePin2<pin, USER, INPUT>));
sketch\common/serial.h:247:1:   required from here
   70 | #define USE_PIN_INPUT(PIN, CLASS) static_assert( sizeof( PO_ResourceTracking::UsePin<PIN, CLASS, true>), #CLASS)
sketch\common/resources.h:36:18: error: ambiguating new declaration of 'PO_SubSystems::PO_SERIAL PO_ResourceTracking::IsUsing(PO_Resources::InputPin<16>)'
   36 |   friend USED_BY IsUsing(RESOURCE x) { return {}; }
sketch\common/resources.h:36:18: note: old declaration 'PO_SubSystems::PO_BLADE_DETECT PO_ResourceTracking::IsUsing(PO_Resources::InputPin<16>)'
Thanks,
Rick
Post your config.
#define NUM_BLADES 13
#define VOLUME 2500
const unsigned int maxLedsPerStrip = 200;
#define CLASH_THRESHOLD_G 4.5
#define SAVE_STATE
#define ENABLE_SSD1306
#define FETT263_TWIST_ON
#define FETT263_MULTI_PHASE
#define ENABLE_SERIAL
#define SHARED_POWER_PINS
#define AUREBESH
Preset blade[] = {
 { "Father;common", "/Father/tracks/Father.wav",
//1- Emitter
//2- Blade
StylePtr<Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<14000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-4000>,Int<-400>>,RgbArg<BASE_COLOR_ARG,Red>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Red>>>,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>>,
  TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RgbArg<IGNITION_COLOR_ARG,White>,40>,TrFade<1200>>,EFFECT_IGNITION>,
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
  LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,DarkOrange>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<>,Mult<IntArg<IGNITION_OPTION2_ARG,7992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,19992>,Int<98304>>>>>>>(),
//3- Front Ring
//4- Front
//5- Back Ring
StylePtr<Layers<
  Pulsing<Black,RgbArg<BASE_COLOR_ARG,Red>,2000>,
  TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,White>>,TrFade<1200>>,EFFECT_IGNITION>,
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,White>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Int<0>>,EFFECT_BLAST>,
  Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<0>>,EFFECT_CLASH>,AlphaL<White,Int<0>>>,
  LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,DarkOrange>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,DarkOrange>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrFadeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<1200>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Pulsing<Black,RgbArg<BASE_COLOR_ARG,Red>,8000>>>>(),
//6- Back Led
StylePtr<Layers<
//7- Plasma Ring
//8- Front Led
StylePtr<Layers<
//9- Sides
//10- Soundboard
//11- Crystal
//12- Motor 1 - Plasma Gate
//13- Motor 2 - Front
" darth \n vader"},
Preset chassis[] = {
//1- Emitter
   StylePtr<Layers<
  Stripes<3000,-2400,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<4000>,Black,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Red>>>,
  InOutTrL<TrColorCycleX<IgnitionTime<1500>,0,800>,TrColorCycleX<RetractionTime<800>,800,0>,ColorCycle<RgbArg<BASE_COLOR_ARG,Red>,25,40,RgbArg<BASE_COLOR_ARG,Red>,25,300,6000>>>>(),
//2- Blade
//3- Front Ring
StylePtr<Layers<
//4- Front
   StylePtr<Layers<
//5- Back Ring
StylePtr<Layers<
//6- Back Led
StylePtr<Layers<
//7- Plasma Ring
StylePtr<Layers<
//8- Front Led
StylePtr<Layers<
//9- Sides
StylePtr<Layers<
//10- Soundboard
StylePtr<Layers<
//11- Crystal
StylePtr<Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Red>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Red>>>,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,SmoothStep<ClashImpactF<>,Int<-4000>>>,TrFadeX<Scale<ClashImpactF<>,Int<100>,Int<300>>>>,EFFECT_LOCKUP_BEGIN>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Int<0>>,TrSparkX<Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Int<0>>>>,EFFECT_LOCKUP_END>,
  LockupTrL<AlphaL<RgbArg<LB_COLOR_ARG,White>,Int<0>>,TrInstant,TrConcat<TrInstant,Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrFade<1000>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
  InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,TransitionLoop<RgbArg<BASE_COLOR_ARG,Red>,TrConcat<TrBoing<1200,2>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Red>>,TrFade<1200>>>>>>(),
	StyleNormalPtr<Rgb<240,0,0>,WHITE,300,800>(),
StylePtr<Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,Black,Black,Mix<Int<7710>,Black,Black>,Black,Mix<Int<19276>,Black,Black>>,Black>,Black>,
  TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<400>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<150,0,0>>,TrFade<1000>>,EFFECT_IGNITION>,
  TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<BLAST_COLOR_ARG,White>,TrFade<300>>,EFFECT_BLAST>,
  TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,White>,TrFade<300>>,EFFECT_CLASH>,
  LockupTrL<TransitionEffect<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  LockupTrL<Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,White>,TrFade<400>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
  LockupTrL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<CLASH_COLOR_ARG,White>>,BrownNoiseFlickerL<RgbArg<CLASH_COLOR_ARG,White>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<CLASH_COLOR_ARG,White>,RotateColorsX<Int<3000>,RgbArg<CLASH_COLOR_ARG,White>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<CLASH_COLOR_ARG,White>,RotateColorsX<Int<3000>,RgbArg<CLASH_COLOR_ARG,White>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<CLASH_COLOR_ARG,White>,RotateColorsX<Int<3000>,RgbArg<CLASH_COLOR_ARG,White>>>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,HumpFlicker<Mix<TwistAngle<>,RgbArg<CLASH_COLOR_ARG,White>,RotateColorsX<Int<3000>,RgbArg<CLASH_COLOR_ARG,White>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<CLASH_COLOR_ARG,White>,RotateColorsX<Int<3000>,RgbArg<CLASH_COLOR_ARG,White>>>>,100>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  AlphaL<RotateColorsX<Variation,White>,Int<0>>,
  InOutTrL<TrInstant,TrInstant>>>(),
" darth \n vader"},
 { 0,
//1- Emitter
	SubBlade(26, 53, WS281XBladePtr<186, bladePin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >()),
//2- Blade
	SubBlade(54, 185, NULL),
//3- Front Ring
	SubBlade(0, 19, NULL),
//4- Front Leds
	SubBlade(20, 25, NULL),
//5- Back Ring
	SubBlade(0, 19, WS281XBladePtr<23, blade6Pin, Color8::GRB, PowerPINS<bladePowerPin1> >()),
//6- Back Led
	SubBlade(20, 22, NULL),
//7- Plasma Ring
	SubBlade(0, 19, WS281XBladePtr<23, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2> >()),
//8- Front Led
//9- Sides
        WS281XBladePtr<6, blade7Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
//10- Soundboard
        WS281XBladePtr<6, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
//11- Crystal
        WS281XBladePtr<3, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin2> >(),
//12- Motor 1
	SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin3, -1, -1, -1>(),
//13- Motor 2
	SimpleBladePtr<CH1LED, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(),
CONFIGARRAY(blade) },
{ NO_BLADE,
//1- Emitter
//2- Blade
//3- Front Ring - Blue Data Wire to rx
//4- Front Leds
//5- Back Ring
//6- Back Led
//7- Plasma Ring
//8- Front Led
//9- Sides
//10- Soundboard - Blue Data wire to Data4
//11- Crystal
//12- Motor 1
//13- Motor 2
CONFIGARRAY(chassis) },
You’ll need to remove ENABLE_SERIAL.
rxPin cannot be used for serial AND blade ID at the same time.
What it supposed to not happen when serial is disabled ? No serial monitor ? Anything else ?
ENABLE_SERIAL enables a serial port on rxPin/txPin which you can use to connect to a bluetooth module (or anything else with an uart) the serial port behaves a lot like the serial monitor, but is separate. ENABLE_SERIAL does not affect the regular (usb-based) serial monitor.
Thanks, couldn’t remember that entire bit since it’s been forever since I’ve seen rxPin come up.
That was easy, thanks a lot for your help guys :slight_smile:
