Hi gang,
I’m trying to use a rotary encoder to toggle between blade color presets, a clockwise turn advancing to the next preset, counter-clockwise reversing back up to the previous preset. The central push-button switch on the encoder currently activates/deactivates the blade.
Does anyone have a successful config file for this? Below is what I’m working from with the help of a neighbor, and we can’t seem to figure it out. I’m using the attached wiring schematic and rotary encoder.
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
#define SAVE_STATE
#define ENABLE_ROTARY_SWITCH
{ "TheBalance", "tracks/boot.wav",
StyleFirePtr<RED, YELLOW, 1>(), "fire"},
StyleFirePtr<BLUE, CYAN, 1>(), "blue fire"},
StyleStrobePtr<WHITE, Rainbow, 15, 300, 800>(), "strobe"}
{ 0, WS2811BladePtr<144, WS2811_800kHz>(), CONFIGARRAY(presets) },
//Button AuxButton(BUTTON_AUX, auxPin, "aux");
#ifdef CONFIG_ROTARY
#define ROTARY_POSITIONS 12 // Number of positions on your rotary switch (matches preset count)
// Define rotary encoder pins
#define ROTARY_ENCODER_CLK 15 // CLK pin
#define ROTARY_ENCODER_DT 13 // DT pin
#define ROTARY_ENCODER_SW 14 // SW pin (button)
ChangePresetRotaryReceiver rotary_receiver;
Rotary<ROTARY_ENCODER_CLK, ROTARY_ENCODER_DT> rotary(&rotary_receiver);
//Button PowerButton(ROTARY_ENCODER_SW, powerButtonPin, "pow");
//RotarySwitch rotarySwitch(ROTARY_PIN1, ROTARY_PIN2, ROTARY_PIN3, ROTARY_PIN4, ROTARY_POSITIONS);
/*RotaryEncoder rotary_encoder(ROTARY_ENCODER_CLK, ROTARY_ENCODER_DT);
// This class handles rotary encoder events to change presets
class RotaryEncoderHandler : public SaberBase {
public:
void Loop() override {
rotary_encoder.Loop();
// If the encoder has been rotated
int32_t change = rotary_encoder.getChange();
if (change != 0) {
// Calculate new preset
int32_t current = current_preset_;
int32_t next = current + change;
// Wrap around if needed
if (next < 0) next = NELEM(presets) - 1;
if (next >= NELEM(presets)) next = 0;
// Change preset
if (next != current) {
current_preset_ = next;
SaberBase::DoEffect(EFFECT_CHANGE_PRESET, next);
RotaryEncoderHandler rotary_handler; */
// This function connects the rotary switch to the preset selection
/*class RotaryEvent : public Event {
public:
RotaryEvent() : Event(EVENT_CHANGE_PRESET) {}
bool IsHandled() override {
if (rotarySwitch.available()) {
int position = rotarySwitch.position();
if (position >= 0 && position < NELEM(presets)) {
current_preset_ = position;
return true;
return false;
//RotaryEvent rotary_event_handler;
