Hey all,
I have a 5mm RGB LED in a crystal chamber. It is not mixing colours the same as the NPXL LED’s/blade colours.
I think I know the reason, and that is that I wired the green and blue legs opposite to the diagram from Fredrik’s site. Red is on power pin4, green is on 5, and blue on 6.
Is there a way to adjust the config to fix this, or would I need to rewire those two pads?
Config below:
#define NUM_BLADES 2
#define NUM_BUTTONS 1
#define VOLUME 600
#define CLASH_THRESHOLD_G 3.0
#define SAVE_STATE
#define SHTOK_GESTURE_IGNITION
{ "CrimsonMenace", "tracks/CrimsonMenace.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>> ,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<10,0,0>>,3000>>>>(), "dark"},
{ "TheBoldOne", "tracks/TheBoldOne.wav",
StylePtr<Layers<Stripes<30000,-400,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,50,200>>,RotateColorsX<Variation,Rgb<50,130,255>>,RotateColorsX<Variation,Rgb<0,20,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<30000,-400,RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,50,200>>,RotateColorsX<Variation,Rgb<50,130,255>>,RotateColorsX<Variation,Rgb<0,20,128>>> ,BlastL<NavajoWhite>,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,4,10>>,3000>>>>(), "light"},
{ "Duke", "tracks/Duke.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>> ,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<10,0,0>>,3000>>>>(), "assassin"},
{ "Empress", "tracks/Empress.wav",
StylePtr<InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<Red,Rgb<120,0,0>>,DeepSkyBlue,200,100,400>,Pulsing<Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,3500>,AudioFlicker<Red,White>>,White,80,50>,800,500,Black>>(),
StylePtr<InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<Red,Rgb<120,0,0>>,DeepSkyBlue,200,100,400>,Pulsing<Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,Gradient<AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>,BrownNoiseFlicker<White,Strobe<SteelBlue,White,50,1>,100>,AudioFlicker<Red,Rgb<120,0,0>>,AudioFlicker<Red,Rgb<120,0,0>>>,3500>,AudioFlicker<Red,White>>,White,80,50>,800,500,Black>>(), "vader"},
{ "KRossguardv3", "tracks/TFA_Duel.wav",
StylePtr<Layers<StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<25,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>, RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,LockupTrL<BrownNoiseFlickerL<White,Int<50>>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<300>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<White,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,BlastL<White>,LocalizedClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<StyleFire<BrownNoiseFlicker<RotateColorsX<Variation,Red>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<25,0,0>>,RotateColorsX<Variation,Rgb<60,0,0>>>,300>, RotateColorsX<Variation,Rgb<80,0,0>>,0,6,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>,FireConfig<10,1000,2>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,LockupTrL<BrownNoiseFlickerL<White,Int<50>>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<300>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<White,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,BlastL<White>,LocalizedClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(), "unstable"},
{ "GeneralPrincess", "tracks/Royalty.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DodgerBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>> ,BlastL<White>,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,DodgerBlue>,RotateColorsX<Variation,Rgb<0,4,10>>,3000>>>>(), "princess"},
{ "FinalSteps", "tracks/FinalSteps.wav",
StylePtr<InOutTr<Layers<Mix<SwingSpeed<400>,AudioFlicker<RotateColorsX<Variation,Rgb<255,160,0>>,RotateColorsX<Variation,Rgb<84,60,0>>>,Mix<SwingSpeed<600>,RotateColorsX<Variation,Rgb<255,160,0>>,RotateColorsX<Variation,BlanchedAlmond>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<AudioFlicker<Blue,SteelBlue>,Bump<Int<0>,Int<9000>>>,TrFade<600>>,EFFECT_IGNITION>,ResponsiveBlastL<White>,ResponsiveClashL<White,TrInstant,TrFade<400>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Red,300>,50,1>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>>,ResponsiveDragL<BrownNoiseFlickerL<White,Int<300>>,TrWipeIn<400>,TrFade<400>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveMeltL<Mix<TwistAngle<>,OrangeRed,Orange>,TrWipeIn<600>,TrSmoothFade<600>>>,TrWipe<150>,TrWipeIn<300>,Black>>(),
StylePtr<InOutTr<Layers<Mix<SwingSpeed<400>,AudioFlicker<RotateColorsX<Variation,Rgb<255,160,0>>,RotateColorsX<Variation,Rgb<84,60,0>>>,Mix<SwingSpeed<600>,RotateColorsX<Variation,Rgb<255,160,0>>,RotateColorsX<Variation,BlanchedAlmond>>>,TransitionEffectL<TrConcat<TrInstant,AudioFlicker<Blue,SteelBlue>,TrFade<600>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<AlphaL<White,Int<0>>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<400>>,ResponsiveLightningBlockL<AlphaL<White,Int<0>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>>,TrWipe<150>,TrWipeIn<300>,Pulsing<RotateColorsX<Variation,Rgb<255,160,0>>,RotateColorsX<Variation,Rgb<84,60,0>>,2000>>>(), "rey"},
{ "YoungSolo", "tracks/General.wav",
StylePtr<InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<Green,Rgb<0,200,0>>,White,200,100,400>,Pulsing<Gradient<AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>>,Gradient<AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>>,3500>,RandomPerLEDFlicker<White,Green>>,White,50,80>,180,300,Black>>(),
StylePtr<InOutHelper<LocalizedClash<Lockup<Blast<AudioFlicker<Green,Rgb<0,200,0>>,White,200,100,400>,Pulsing<Gradient<AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>>,Gradient<AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>,BrownNoiseFlicker<White,Strobe<Red,White,50,1>,100>,AudioFlicker<Green,Rgb<0,200,0>>,AudioFlicker<Green,Rgb<0,200,0>>>,3500>,RandomPerLEDFlicker<White,Green>>,White,50,80>,180,300,Black>>(), "rescue"},
{ "Ascension", "tracks/JFO2.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<50,50,75>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<200>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<50,50,75>>> ,BlastL<White>,InOutTrL<TrInstant,TrFade<300>,Pulsing<RotateColorsX<Variation,Rgb<100,100,150>>,RotateColorsX<Variation,Rgb<4,4,6>>,3000>>>>(), "sorceror"},
{ "Traveler", "tracks/Darkness.wav",
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<90,24,0>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<160,43,0>>>,TrDelay<30000>,RotateColorsX<Variation,DarkOrange>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,LockupTrL<BrownNoiseFlickerL<White,Int<50>>,TrConcat<TrInstant,White,TrFade<200>>,TrFade<300>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<White,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,BlastL<White>,LocalizedClashL<White>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Stripes<16000,-1000,RotateColorsX<Variation,DarkOrange>,Pulsing<RotateColorsX<Variation,Rgb<90,24,0>>,RotateColorsX<Variation,DarkOrange>,800>,RotateColorsX<Variation,DarkOrange>>,TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<160,43,0>>>,TrDelay<30000>,RotateColorsX<Variation,DarkOrange>,TrFade<800>>,EFFECT_FORCE>,InOutTrL<TrInstant,TrFade<300>,Mix<IsLessThan<SlowNoise<Int<3000>>,Int<10000>>,RandomFlicker<RotateColorsX<Variation,DarkOrange>,RotateColorsX<Variation,Rgb<90,24,0>>>,Black>>>>(), "fallen"},
{ "TheBoldOne", "tracks/jfo.wav",
&style_charging,
SimpleBladePtr<CH1LED, CH2LED, CH3LED, NoLED, bladePowerPin4, bladePowerPin5, bladePowerPin6, -1>()
, CONFIGARRAY(presets) },
Thanks
