Rfid crystal removal detection
Hi, first time poster looking for some assistance.
I have presets selection working via RFID values from different crystals. It currently works to switch between the specified presets when a crystal RFID tag is read but I would like it to switch to a missing crystal preset, similar to removing a blade using blade detect, when no RFID tag is detected. I’m assuming it is constantly searching for RFID, as it quickly changes once a different crystal is placed near the antenna.
The behavior I would like to change is when the crystal is removed, the preset persists. I would like it to act/sound broken when the ignite button is pressed but no crystal is detected. And perhaps a sound plays as soon as it no longer detects a crystal. Pretty much the same idea as the many examples i have seen for blade detect.
Any ideas how I might go about this?
Currently, it will load a default preset on bootup as well as allow preset switching via button presses without using Crystals at all. I think i will have to disable this.
Proffie OS 7.14
Proffieboard v2.2
RF125-ps RFID reader
The rf125-ps doesn’t say or do anything when the crystal is removed, so it’s not possible to implement based on the output from that only. You would need an extra signal, then you could use blade detect, or a different rfid reader to make it work.
I have something similar set up for an arduino board as well as an esp32c3 where I believe it keeps checking for a tag Id at the serial connection and if no RFID is detected within a time frame it sets an RGB LED to off, otherwise it sets the colour as defined for the specific RFID value. I can’t make much sense of this part of the code but I could share it if you’d like to see it. The reader board doesn’t need to do anything other than send the hex information to the serial input as, in this case, it is the main board’s programming that is doing the checking for the tag Id every so often. Or at least that is how I understand it. I am hoping to bring this feature over to my proffieboards.
Updated to share link to original project/code for arduino board
link to code: kyber_colors.ino - Google Drive
video: https://www.youtube.com/watch?v=wD9zHP9LdAc
That’s cool. It seems to be based on an RDM6300 rfid reader, which apparently keeps sending data for each rfid check. The RF125-PS does not do that. Unfortunately the RDM6300 is quite a bit bigger than the RF125-PS. (20x12mm vs 38.5x19mm)
OK, that’s too bad. I definitely can’t fit the RDM6300 into my saber. It looks like I will have to go the detect pin/switch route. Thanks!
I think I’d like to use the blade detection feature for crystal detection using a switch the crystal will be held against to short a blade detect pin on the proffieboard (Tx) to gnd.
I believe this would be no different than the blade detect pin being shorted to the blade negative on a shtok nxpl pcb but I’m not 100% sure since the blade negative isn’t really gnd. Do I need to do any pull up or pull down resistors for this to work?
To my knowledge you won’t need any resistors added to the circuit for this to work. Check out this video I made to show off my saberkraft flame hilt.
About 20 seconds in I toggle a latching switch in the control box to trigger blade detect which in essence seems like what you want to do with your crystal. Wiring it up was super simple,
Switch common to Free 1
Left or right leg to GND
The hardest part for me was to figure out how the config file needed to be setup.
For you I believe it’ll be the same thing except with the switch common going to TX since you’re using proffie v2.2. Have you considered using a type of magnetic setup similar to what I’ve seen in the goth 3designs graflex grand master chassis?
I’m not too familiar with how the goth grand master chassis work but i am planning this hilt to be compatibility with the disney RFID-equipped kyber crystals so i can’t have a tightly fitting crystal holder like the goth chassis.
My design is much like the Disney Savis workshop lightsaber chassis, only I am using a momentary switch with a spring behind it to compress it against the crystal to signal that a crystal is present (circuit closed) and when unpressed (circuit open) to signal when the crystal is removed. It also doubles as a method to hold the crystals in place.
Essentially I want it to behave the same way as the blade detect feature. No ignition and glitchy sounds when no crystal is present and standard behaviour when present. Except at this point it will select the blade style based on a RFID tag in the crystal.
This is what @NoSloppy told me yesterday:
But I don’t know if it is possible to have more than one blade detect:
  • one for the main blade
    and
  • one for a crystal or other blade(s)
Can more than one BD be coded in the config ? Or would the second one need to be coded “something else” ?
Yes you can do multiple blade detects but it requires adding some code to write sequentially incremented blade detects. There’s some posts by @shadowfoil regarding it somewhere here on this forum.
Found this thread:
multiple blades use blade detect:
Add this to events.h
BUTTON_BLADE_DETECT = 256,
BUTTON_BLADE_DETECT2 = 2048,
BUTTON_BLADE_DETECT3 = 4096,
Add this to your config header
#define BLADE_DETECT_PIN 8
#define BLADE_DETECT_PIN2 9
#define BLADE_DETECT_PIN3 22
Add this to your props file
#ifdef BLADE_DETECT_PIN
  case EVENTID(BUTTON_BLADE_DETECT, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_ON):
  case EVENTID(BUTTON_BLADE_DETECT, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_OFF):
    // Might need to do something cleaner, but let's try this for now.
    blade_detected_ = true;
    FindBladeAgain();
    return true;
  case EVENTID(BUTTON_BLADE_DETECT, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_ON):
  case EVENTID(BUTTON_BLADE_DETECT, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_OFF):
    blade_detected_ = false;
    FindBladeAgain();
    SaberBase::DoBladeDetect(false);
    return true;
#ifdef BLADE_DETECT_PIN2
  case EVENTID(BUTTON_BLADE_DETECT2, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_ON):
  case EVENTID(BUTTON_BLADE_DETECT2, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_OFF):
    blade2_detected_ = true;
    FindBladeAgain();
    return true;
  case EVENTID(BUTTON_BLADE_DETECT2, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_ON):
  case EVENTID(BUTTON_BLADE_DETECT2, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_OFF):
    blade2_detected_ = false;
    FindBladeAgain();
    return true;
#ifdef BLADE_DETECT_PIN3
  case EVENTID(BUTTON_BLADE_DETECT3, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_ON):
  case EVENTID(BUTTON_BLADE_DETECT3, EVENT_LATCH_ON, MODE_ANY_BUTTON | MODE_OFF):
    blade3_detected_ = true;
    FindBladeAgain();
    return true;
  case EVENTID(BUTTON_BLADE_DETECT3, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_ON):
  case EVENTID(BUTTON_BLADE_DETECT3, EVENT_LATCH_OFF, MODE_ANY_BUTTON | MODE_OFF):
    blade3_detected_ = false;
    FindBladeAgain();
    return true;
private:
  bool blade2_detected_ = false;
  bool blade3_detected_ = false;
Add this to ProffieOS.ino
LatchingButtonTemplate<FloatingButtonBase<BLADE_DETECT_PIN>>
  BladeDetect(BUTTON_BLADE_DETECT, BLADE_DETECT_PIN, "blade_detect");
LatchingButtonTemplate<FloatingButtonBase<BLADE_DETECT_PIN2>>
  BladeDetect2(BUTTON_BLADE_DETECT2, BLADE_DETECT_PIN2, "blade_detect");
LatchingButtonTemplate<FloatingButtonBase<BLADE_DETECT_PIN3>>
  BladeDetect3(BUTTON_BLADE_DETECT3, BLADE_DETECT_PIN3, "blade_detect");
Sorry @starwalker ,
I do not want to hijack your thread but IMHO this could be helpful to you too.
@NoSloppy :
  • Is #define BLADE_DETECT_PIN 8 the same as #define BLADE_DETECT_PIN blade5Pin ?
  • current ProffieOS.ino has an extra line in the #ifdef BLADE_DETECT_PIN:
USE_PIN_OUTPUT(BLADE_DETECT_PIN, PO_SubSystems::PO_BLADE_DETECT);
How to update USE_PIN_OUTPUT line to BladeDetect2 & 3 ?
Thank you,
FYI, I am working on a little helper function to reduce repetition in the case switch but since I used a bit of AI (not for the code but for coming up with pretty names, it is good at that bit :rofl:), I will test it first before posting it.
Edit: these are the names of the function and varibles I think of using:
“UpdateBladeInserted (int blade_detect_index, bool blade_inserted) { // blade_detect_index = 1, 2 or 3”
Assuming you have a V3 board, you can use the pin table on this page:
https://fredrik.hubbe.net/lightsaber/v6/
To check the different names/numbers that refers to the same pin.
You would just add:
USE_PIN_OUTPUT(BLADE_DETECT_PIN2, PO_SubSystem::PO_BLADE_DETECT);
USE_PIN_OUTPUT is a macro that generates an error if you try to use the same pin for two different things. Unfortunately this hasn’t worked out as well as I’d hoped, so it’s not used much in the code.
If, instead of shorting the blade detect pin to gnd, i use battery positive, do i need to change anything in the default proffie OS code since it the signal will be either floating or high? Or does the code treat the blade detect being pulled high or low the same way?
Blade detect is special.
It works like a button, but it differentiates between floating and non-floating. (It does not currently differentiate between “pulled high” and “pulled low” though.)
So you shouldn’t have to change anything, blade detect works with both “short to GND” and “short to +”.
I have this working but not as well as I’d like. The different RFID tags will change the preset but it seems there is sometimes a delay before it gets detected. I don’t believe this is an antenna or positioning issue as i hold it still and after about 5-10 seconds it will be detected. Is there a setting I can change to have it scan more frequently or is this all down to the RIFD reader board itself?
Are you using blade detect and if so has the hilt been at rest or been freshly turned on via a kill switch? In other words, is this during a cold or a hot swap situation? I ask because yes there is a short delay in blade detect present during a cold swap even in what I use it for.
I currently have the blade detect jumpered. Freshly turned on with kill switch.
If i wait about 10 seconds before swapping in a new RFID tag, it does change almost instantly. So it may not be an issue for me afterall.
I was trying to detect a second tag immediately after the last one was detected. I thought the delay was always happening between placing the new tag next to the antenna and it being detected. But it seems like more of a delay between detecting a tag and being available to detect a new one.
It’s all down to the rfid board itself.
You would need to find a different rfid board if you want to change this.
