I can contribute this from a config file I did for a guy doing that in his build, but there was also a motor, and we used SnapshotBladeID. It might help?
#define NUM_BLADES 7
#define VOLUME 1800
#define CLASH_THRESHOLD_G 3.5
#define ENABLE_SSD1306
#define ENABLE_SERIAL
#define SHARED_POWER_PINS
#define BLADE_DETECT_PIN blade4Pin
#define ENABLE_POWER_FOR_ID PowerPINS<bladePowerPin2,bladePowerPin3>
#define IDLE_TIME_OFF 60 * 5 * 1000
#define PLI_OFF_TIME 60 * 5 * 1000
#define ENABLE_SPINS
#define SAVE_STATE
#include "../props/saber_BC_buttons.h"
// Blade 1 - Main Blade
// Blade 2 - Crystal Top
// Blade 3 - Crystal Bottom
// Blade 4 - LED strips
// Blade 5 - Arc Reactor
// Blade 6 - Speaker 3mm
// Blade 7 - Motor
Preset crystal[] = {
{ "Cantina;common", "tracks/Cantina.wav",
// Main Blade
StylePtr<Layers<
// Base Blue
Mix<SwingSpeed<400>,AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,Mix<SwingSpeed<600>,RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<150,150,255>>>>,
// Dim Blade 50% "Power Save" button combo
EffectSequence<EFFECT_POWERSAVE,
AlphaL<Black,Int<16384>>,
AlphaL<Black,Int<0>>>,
// Clash 1 - BladeAngle responsive. Yellowish impact
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,White,TrInstant,TrFade<300>,EFFECT_CLASH>,Bump<Scale<BladeAngle<>,Int<25000>,Int<8000>>,Int<18000>>>,TrFade<600>>,EFFECT_CLASH>,
// Stab - OrangeRed stripes
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<300>,AlphaL<Stripes<5000,1000,Orange,DarkOrange,Rgb<150,60,0>,Rgb<60,30,0>,Rgb<150,14,0>,OrangeRed>,SmoothStep<Int<20000>,Int<20000>>>,TrJoin<TrSmoothFade<900>,TrWipe<700>>>,EFFECT_STAB>,
// Blast
// Impact Flash - BC always
TrInstant,GreenYellow,TrDelay<25>>,EFFECT_BLAST>,
// Waves
BlastL<White,850,250,351>,
// Impact point afterimage
//AlphaL<TransitionEffectL<TrConcat<TrFade<200>,Red,TrFade<600>>,EFFECT_BLAST>,BlastF<700,250,100000>>,
AlphaL<TransitionEffectL<TrConcat<TrFade<300>,Rgb<255,70,70>,TrFade<300>>,EFFECT_BLAST>,BlastF<700,250,100000>>,
// Impact point
//BlastL<White,500,350,100000>,
BlastL<White,300,350,100000>,
// Lockup 1 - BC custom range mid-blade to hilt w/random strobe flash
TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,
LockupTrL<Layers<
//Random Strobe Flash no dimming
AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>>,Int<32768>>,
//AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<3>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,
// Bottom Layer Bump - random width
AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,
// Top Layer Bump - fixed width
AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<9000>>>>,
// Begin Lockup Transition
TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,
// End Lockup Transition
TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<225>>,EFFECT_LOCKUP_BEGIN>,
// Non-Responsive Drag - BC custom drag fadeout
LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrFade<150>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_DRAG>,
// Lightning Block - Non-responsive. BC custom color (purple hint w/ random strobe flashes because....lightning)
LockupTrL<Layers<
//Random Strobe Flash and 16000 = 50% base blade dimming to make lb pop
AlphaL<Black,Int<16000>>,
AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,
AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<
Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,
Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,
Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,
// Begin Lightning Transition
TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,
// End Lightning Transition
TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>> >,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
// Melt - BC custom melt effects, uses twistangle<>
LockupTrL<
// OS 6 (Based on "Intensity Melt" - Fett263. Remap Fire to travel tip->emitter, Custom Begin and End Transitions)
AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,Rgb16<20393,93,93>,DarkOrange>,Mix<TwistAngle<>,Rgb16<20393,93,93>,Orange>,0,4,5,4000,10>>,
// Melt Shape
SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<4000>>>,
// Melt Begin and End transitions
TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<600>,AlphaL<Red,SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,TrExtend<3000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,TrFade<3000>>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipeSparkTip<White,400>,TrWipeInX<WavLen<EFFECT_RETRACTION>>>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Green,Bump<Int<0>,Int<1000>>>,TrDelay<90>,AlphaL<DodgerBlue,Bump<Int<0>,Int<1000>>>,TrFade<100>,AlphaL<DeepSkyBlue,Bump<Int<0>,Int<1000>>>,TrDelay<200>>,EFFECT_PREON>,
// On-Demand Battery Level
AlphaL<TransitionEffectL<TrConcat<TrSmoothFade<500>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Scale<BatteryLevel,Int<0>,Int<35000>>,Int<-1>>>,TrDelay<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Scale<BatteryLevel,Int<0>,Int<35000>>,Int<-1>>>,TrSmoothFade<1000>>,EFFECT_BATTERY_LEVEL>,Ifon<Int<0>,Int<32768>>>
// Crystal Top
StylePtr<Layers<
// Crystal Blue
Stripes<1000,-2000,RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>,Black>,
TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,160>>>,TrDelay<3000>,RotateColorsX<Variation,Blue>,TrFade<800>>,EFFECT_FORCE>,
TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_CLASH>,
TransitionEffectL<TrConcat<TrInstant,White,TrFade<400>>,EFFECT_BLAST>,
LockupL<AudioFlicker<White,Blue>,AudioFlicker<Yellow,SteelBlue>,Int<32768>,Int<32768>,Int<32768>>,
TransitionEffectL<TrConcat<TrInstant,White,TrFade<500>>,EFFECT_LOCKUP_END>,
TransitionEffectL<TrConcat<TrInstant,White,TrFade<500>>,EFFECT_DRAG_END>,
LockupTrL<Pulsing<BrownNoiseFlicker<Red,Black,300>,Yellow,2000>,TrFade<300>,TrFade<300>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrConcat<TrInstant,White,TrSmoothFade<1000>>,TrConcat<TrSmoothFade<500>,White,TrSmoothFade<500>>,Pulsing<RotateColorsX<Variation,Blue>,Black,3000>>
// Crystal Bot
StylePtr<Layers<
// Crystal Blue
InOutTrL<TrConcat<TrInstant,White,TrSmoothFade<1000>>,TrConcat<TrSmoothFade<500>,White,TrSmoothFade<500>>,Pulsing<Black,RotateColorsX<Variation,Blue>,3000>>
// LED Strips
StylePtr<Layers<
InOutTrL<TrConcat<TrInstant,White,TrSmoothFade<1000>>,TrConcat<TrSmoothFade<500>,White,TrInstant>,ColorCycle<RotateColorsX<Variation,Blue>,10,30,Black,100,3000,1>>
// Arc Reactor
StylePtr<Layers<Black,
Pulsing<AlphaL<BrownNoiseFlicker<White,SteelBlue,10>,Int<16000>>,BrownNoiseFlicker<White,SteelBlue,200>,1500>,
TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrFade<400>>,EFFECT_CLASH>,
TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrFade<400>>,EFFECT_BLAST>,
LockupL<AudioFlicker<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Blue>,AudioFlicker<Yellow,SteelBlue>,Int<32768>,Int<32768>,Int<32768>>,
TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrFade<500>>,EFFECT_LOCKUP_END>,
TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrFade<500>>,EFFECT_DRAG_END>,
InOutTrL<TrConcat<TrInstant,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrSmoothFade<1000>>,TrConcat<TrSmoothFade<500>,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrSmoothFade<500>>,Pulsing<Rgb<70,70,70>,Rgb<20,20,20>,2000>>
// Speaker 3mm White LED Data NA Power 6
StylePtr<Layers<
Blinking<Black,White,1500,500>,
InOutTrL<TrInstant,TrInstant,Sequence<White,Black,200,30,0b0,0b10101010101000>>
// Motor Data NA Power 5
StylePtr<InOutHelper<Rgb<128,128,128>,300,800>>(),
"cantina"}
Preset crystal_out[] = {
{ "WHITE;common", "tracks/Tron.wav",
// Main Blade - Blade is plain without crystal inserted...?
StylePtr<Layers<
HumpFlicker<White,SteelBlue,200>,
// Clash
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Moccasin,TrInstant,TrFade<300>,EFFECT_CLASH>,Bump<Scale<BladeAngle<>,Int<25000>,Int<8000>>,Int<18000>>>,TrFade<600>>,EFFECT_CLASH>,
// Blast - for white blades
// Waves
BlastL<EffectSequence<EFFECT_BLAST,Red,Green,Blue,Black>,850,250,351>,
AlphaL<TransitionEffectL<TrConcat<TrFade<300>,Red,TrFade<300>>,EFFECT_BLAST>,BlastF<700,250,100000>>,
// Impact point
BlastL<Black,300,350,100000>,
// Lockup - BC custom range mid-blade
TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,
LockupTrL<Layers<
AlphaL<BrownNoiseFlicker<Yellow,Black,50>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<10000>>>>,
TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<250>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>>,EFFECT_LOCKUP_BEGIN>,
// Lightning Block Non-Responsive
LockupTrL<Layers<
// Melt
LockupTrL<
AlphaL<Mix<TwistAngle<>,Yellow,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,
// Melt Shape
//Melt Begin and End transitions
TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<600>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_MELT>,
// Crystal Top
StylePtr<Black>(),
// Crystal Bottom
StylePtr<Black>(),
// Led Strips
StylePtr<Layers<
Stripes<1000,-2000,HumpFlicker<White,SteelBlue,200>,Black>,
TransitionEffectL<TrConcat<TrInstant,Blinking<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Orange,20,500>,TrFade<400>>,EFFECT_CLASH>,
TransitionEffectL<TrConcat<TrInstant,Blinking<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Orange,20,500>,TrFade<400>>,EFFECT_BLAST>,
LockupTrL<Blinking<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Strobe<Black,Red,15,30>,60,500>,TrConcat<TrInstant,Blinking<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Strobe<BrownNoiseFlicker<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Black,500>,Black,15,30>,60,500>,TrFade<500>>,TrConcat<TrInstant,Blinking<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Strobe<BrownNoiseFlicker<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Black,500>,Black,15,30>,60,500>,TrFade<500>>,SaberBase::LOCKUP_NORMAL>,
LockupTrL<RandomFlicker<Strobe<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Rgb<60,0,255>,50,10>,BrownNoiseFlicker<Rgb<60,0,255>,Black,500>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlickerL<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Int<50>>,TrFade<500>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
LockupTrL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>>,TrConcat<TrInstant,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrFade<400>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_DRAG>,
InOutTrL<TrConcat<TrInstant,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrSmoothFade<1000>>,TrConcat<TrSmoothFade<500>,BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,TrInstant>,ColorCycle<White,10,30,Black,100,3000,1>>
// Arc Reactor
TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<90,0,0>>>,TrDelay<3000>,RotateColorsX<Variation,Red>,TrFade<800>>,EFFECT_FORCE>,
StylePtr<Layers<
StylePtr<Black>(),
"root\ncore"}
{ 700, // clean ID resistor value as per Serial Monitor (blue)
// Main Blade 122 LEDs Data 3 Power 2&3
WS281XBladePtr<122, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
// Crystals - 2 discrete blades for the 2 LEDS Data 1 Power 4
SubBlade(1, 1, WS281XBladePtr<2, bladePin, Color8::GRB, PowerPINS<bladePowerPin4> >()),
SubBlade(0, 0, NULL),
// LED strip (parallel w/ 2nd strip) and Arc reactor 1 LEDs Data 2 Power 6
SubBlade(1, 6, WS281XBladePtr<7, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()),
// Speaker 3mm White LED Data NA Power 1
SimpleBladePtr<CreeXPE2WhiteTemplate<0>, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>(),
SimpleBladePtr<CreeXPE2WhiteTemplate<0>, NoLED, NoLED, NoLED, bladePowerPin5, -1, -1, -1>(),
CONFIGARRAY(crystal), "01_clean_save", },
{830, // cracked ID resistor value as per Serial Monitor (red)
CONFIGARRAY(crystal), "02_cracked_save", },
{ NO_BLADE,
// Main Blade 122 LEDs Data 3 Power 2&3 (orange)
CONFIGARRAY(crystal_out), "03_crystal_out_save" },
